Hairball Posted December 27, 2007 Share Posted December 27, 2007 Has anyone had much experience with using the FC Commander Pro Software? I would love to get some technical assistance if you have. Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3553535 Share on other sites More sharing options...
paulr33 Posted January 2, 2008 Author Share Posted January 2, 2008 i have it - jap and eng version whats up ? Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3561005 Share on other sites More sharing options...
Hairball Posted January 9, 2008 Share Posted January 9, 2008 i have it - jap and eng versionwhats up ? Software was purchased, installed, registered and connected OK to my ECU without a hitch, however when I tried to connect it to two other 'pexi ECU's it failed to establish a connection. I spent a fair bit of time trying to nut it out and it appears to be just the other two ECU's that I have an issue communicating with. So I guess my question is: Is the software only licensed to run on one ECU, or is it the two (non-communicating) ECU's being of a different model/type? The software works seamlessly with my R33 GTR, so my belief is that the issue lies with the fact that the R34 GTR and R34 GTS-T's Apexi ECU's are not compatible with the R33. The only way I have to determine if the problem lies with a license issue or with a software version issue is to get another R33 GTR with the same ECU as mine (about as easy as it sounds). This is where you come into it . In your travels have to come across the quick answer to this question? Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3571013 Share on other sites More sharing options...
WHT11 Posted January 10, 2008 Share Posted January 10, 2008 I need help with my BNR32 power FC D-Jectro, does anyone know where to plug in the wires to the ECU a red and brown from the intake air temp sensor? Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3575460 Share on other sites More sharing options...
paulr33 Posted January 11, 2008 Author Share Posted January 11, 2008 some updates tonight - has been a while... removed the user content section - it was crap updated version info & version matrix updated "does the unit work on auto cars" updated manual links for user manuals updated "what is the fc pro & do i need it" - included identify fake fc pro versions updated "How does the AVC-R compare to the PowerFC boost controller kit?" Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3576877 Share on other sites More sharing options...
paulr33 Posted January 13, 2008 Author Share Posted January 13, 2008 good update today updated "I have the older PowerFC that did not come with a hand controller can I buy a new hand controller separate and use that?" updated "Does the PowerFC have limits?" updated "Help! My car doesn't start once I've installed the PowerFC" updated "Where can I get my PowerFC tuned and how much will it cost me?" updated "My idle is really crappy and it hunts around a lot when on idle. What can I do?" updated "My fuel economy is terrible and I just had a complete tune, Whats wrong?" updated "Boost display without the Boost Control Kit?" updated "Hybrid Apexi PowerFC models and mix n match models, can it be done?" updated "My Skyline R32 GTR has a wierd misfire problem, what's wrong?" updated "Is there a replacement hand controller screen?" updated "I have fried my PowerFC. Is it fixable?" updated "How do I debug knocking, how can I make it go away?" updated "PowerFC Pro - Launch Control" updated "I want to go EPROM/Firmware hacking, Tell me how" Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3578942 Share on other sites More sharing options...
paulr33 Posted January 13, 2008 Author Share Posted January 13, 2008 Software was purchased, installed, registered and connected OK to my ECU without a hitch, however when I tried to connect it to two other 'pexi ECU's it failed to establish a connection.I spent a fair bit of time trying to nut it out and it appears to be just the other two ECU's that I have an issue communicating with. So I guess my question is: Is the software only licensed to run on one ECU, or is it the two (non-communicating) ECU's being of a different model/type? The software works seamlessly with my R33 GTR, so my belief is that the issue lies with the fact that the R34 GTR and R34 GTS-T's Apexi ECU's are not compatible with the R33. The only way I have to determine if the problem lies with a license issue or with a software version issue is to get another R33 GTR with the same ECU as mine (about as easy as it sounds). This is where you come into it . In your travels have to come across the quick answer to this question? this is certainly possible - have a look at the product matrix to find out if its supported by your version of FC pro & cable Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3579873 Share on other sites More sharing options...
paulr33 Posted January 14, 2008 Author Share Posted January 14, 2008 the pfc faq is offline due to a forum bug - it should be fixed soon Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3581353 Share on other sites More sharing options...
paulr33 Posted January 16, 2008 Author Share Posted January 16, 2008 the pfc faq is offline due to a forum bug - it should be fixed soon this has been fixed Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3585569 Share on other sites More sharing options...
HIZOKU Posted January 24, 2008 Share Posted January 24, 2008 alright i have now installed a power FC into my car and im having a issue im not sure if it due to the power fc or what when i give my car the boot then take foot off the accel and put on clutch now and again my car will stall but soon as i let foot off clutch starts up again (like push starting it) has anyone had this issue mind you it is in a evo so i doubt alot of you have Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3601133 Share on other sites More sharing options...
paulr33 Posted January 27, 2008 Author Share Posted January 27, 2008 hi robert, this can happen if you dont do the self idle adjustment properly can you confirm you did this correctly? also i assume you have std bov etc and not an atmo unit ? Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3606305 Share on other sites More sharing options...
NickR33 Posted January 29, 2008 Share Posted January 29, 2008 does anybody know why I just had a retune and now the H/C screen isn't coming on? I will ring the tuner and ask but just thought I would ask here first in case its something really obvious Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3609189 Share on other sites More sharing options...
paulr33 Posted January 29, 2008 Author Share Posted January 29, 2008 if its blank unplugged or loose cable if its locked on the apexi logo wrong hand controller version if its locked on a blank screen (but lit up) then loose connector, damaged connector or damaged hand controller Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3609214 Share on other sites More sharing options...
NickR33 Posted January 29, 2008 Share Posted January 29, 2008 I'm a douche... it wasn't plugged in:/ Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3609302 Share on other sites More sharing options...
paulr33 Posted January 30, 2008 Author Share Posted January 30, 2008 no worries - all good Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3612930 Share on other sites More sharing options...
Proximity Motorsport Posted February 3, 2008 Share Posted February 3, 2008 Hey, I have a RB26DETT FC D-Jetro on its way from nengun and i have the field one touch connecter from greenline. A mate (the_mafia) is re-wiring it to suit my rb20det r32 gtst. He has done the conversion with a normal fc but never djetro. My current mods 3" turboback 2.5" split dump GCG Highflow Turbo Turbosmart boost T HKS Pod Walbro Fuel Pump Fuel Pressure Reg (going to be removed with ecu install) Splitfire Coilpacks Plazmaman Forward intake plenum hybrid fmic plazmaman piping kit when ecu goes in (already have waiting) GTR injectors 3-4" intake pipe Now we have extablised i can use a vacuume line from under plenum and T off to 2 map sensors. What im wondering is i have read the map sensors need to be spliced into standard loom for airflow meter... so do we cut off plug, and just splice 2 new wires to each existing wire in the airflow meter loom. Also air intake temp sensor. Where does it go... have been told this will make tune much easier. So basically is there an aftermarket option (bosch) or something that is cheap or should i source one new from nissan?? Will i need to weld any nipples onto piping anywhere or what? And now for the acc valve. I have a hose going from that to my intake pipe (behind my afm) for now and i have been told i can just put a little breather filter off the valve and leave it at that with the fc... and it will work fine, is this true. Factory oxygen sensor... should i replace it... i have been told they should be done every 40,000km and my guess is mine is still factory one. I have also been told i wont need it with djetro and it would be a waste of money... in that case can i plug off the dump pipe or should i just leave it or should i replace it. thanks alot if you could answer these questions. Yes i have read the faq but i could not find too much relating to my issues in depth. cheers, Leon Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3620842 Share on other sites More sharing options...
SKYRYAN Posted February 4, 2008 Share Posted February 4, 2008 Question *2x R33 GTST Series 2 Skylines Car A: Has Apexi PFC and Z32 AFM Car B: Has stock ECU and stock AFM How simple is it to swap these 2 items between cars as car A is going to be sold and taken back to stockish state. Can we just simply unplug the wiring harness from the ECU's, swap them around and plug right back in and should be fine to drive? *Cars A and B both have stock turbo's and almost identical modifications (FMIC, 3" turbo-back, fuel pump) Also, unplugging the PFC and moving to another vehicle... with this retain the tune or reset all settings? Cheers, Ryan Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3622034 Share on other sites More sharing options...
paulr33 Posted February 4, 2008 Author Share Posted February 4, 2008 Question*2x R33 GTST Series 2 Skylines Car A: Has Apexi PFC and Z32 AFM Car B: Has stock ECU and stock AFM How simple is it to swap these 2 items between cars as car A is going to be sold and taken back to stockish state. Can we just simply unplug the wiring harness from the ECU's, swap them around and plug right back in and should be fine to drive? *Cars A and B both have stock turbo's and almost identical modifications (FMIC, 3" turbo-back, fuel pump) Also, unplugging the PFC and moving to another vehicle... with this retain the tune or reset all settings? Cheers, Ryan if you do a direct swap one for one it should be ok - the worst is it wont idle, if it doesnt then youll need to do DATA INIT to do the self idle adjustment (you will loose the tune). the tune is always retained even with power off and unplugged. its only erased if you do DATA INIT Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3622081 Share on other sites More sharing options...
SKYRYAN Posted February 4, 2008 Share Posted February 4, 2008 Thanks Paul We are going to attempt to swap them around this afternoon. If my car doesn't idle I will check your FAQ for info on the DATA INIT. Great work! Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3622089 Share on other sites More sharing options...
Proximity Motorsport Posted February 4, 2008 Share Posted February 4, 2008 Hey,I have a RB26DETT FC D-Jetro on its way from nengun and i have the field one touch connecter from greenline. A mate (the_mafia) is re-wiring it to suit my rb20det r32 gtst. He has done the conversion with a normal fc but never djetro. My current mods 3" turboback 2.5" split dump GCG Highflow Turbo Turbosmart boost T HKS Pod Walbro Fuel Pump Fuel Pressure Reg (going to be removed with ecu install) Splitfire Coilpacks Plazmaman Forward intake plenum hybrid fmic plazmaman piping kit when ecu goes in (already have waiting) GTR injectors 3-4" intake pipe Now we have extablised i can use a vacuume line from under plenum and T off to 2 map sensors. What im wondering is i have read the map sensors need to be spliced into standard loom for airflow meter... so do we cut off plug, and just splice 2 new wires to each existing wire in the airflow meter loom. Also air intake temp sensor. Where does it go... have been told this will make tune much easier. So basically is there an aftermarket option (bosch) or something that is cheap or should i source one new from nissan?? Will i need to weld any nipples onto piping anywhere or what? And now for the acc valve. I have a hose going from that to my intake pipe (behind my afm) for now and i have been told i can just put a little breather filter off the valve and leave it at that with the fc... and it will work fine, is this true. Factory oxygen sensor... should i replace it... i have been told they should be done every 40,000km and my guess is mine is still factory one. I have also been told i wont need it with djetro and it would be a waste of money... in that case can i plug off the dump pipe or should i just leave it or should i replace it. thanks alot if you could answer these questions. Yes i have read the faq but i could not find too much relating to my issues in depth. cheers, Leon Help please Link to comment https://www.sau.com.au/forums/topic/64201-faq-apexi-powerfc-frequently-asked-questions/page/17/#findComment-3623044 Share on other sites More sharing options...
