when you say off the scale, do you mean it drops to load axis 20 on "map watch"?
if so, then yes you can rescale the load axis to move it around a bit
but remember a 3 bar map sensor is only 2 bar positive pressure
map sensors are listed as 3 bar or 2 bar or 4 bar etc but this includes 1 bar of vacuum or negative pressure (aka vacuum)
so if you have a 3 bar map sensor it will only read to 2bar boost
Yeh it Goes to load axis 20 and you cant see anymore whats happening...
Ok i will try find 4 bar map sensors.. :bunny: if that is my problem,
But when you say rescale the load axis points is this done via the software? And how would i do this? and once this is done am i able to run my 30pounds and be able to see the load points?
Tony thanks for your reply
yeah so reuse datalogit to rescale the map sensor load points
its covered in the PFC FAQ how to do it
and if you change to a 4 bar map sensor thats also covered in the PFC FAQ how to install and set it up
you need to use a new offset and PIM values when you change the map sensor (its in the FAQ)
Any other recommendations for a unstable and sometimes high idle (1000rpm)
I have leaned the idle right out and it definately helps when rolling to the lights as before it used to rev up and down. Now at idle, sometimes its fine at 700rpm but generally its around 900/1000rpm and sometimes back to 700rpm, but the majority of the time its high, seems to have a mind of its own.
Any recommendations as i dont want to reset it.
Finally fixed it. I switched the o2 sensor off and bingo, idles like a baby. Just ordered a new o2 sensor, hopefully it does the trick
please pardon my ignorance, but i have been dealing with an issue with my car and came here for a possible solution to my problem. ok the car is a 95 S14 with an RB25DET NEO out of an R34. the following mods have been performed. greddy plenum, Q45 90mm T/B, 650cc injectors, T67 turbo,greddy 50mm racegate, turbular manifold..the unit has been tuned and car runs fine until i let my foot off the gas. even while cruising and not in boost, if i let off the gas she will stall. i can catch it with my foot by hitting the gas pedal but if i dont modulate the gas it will still try to stall out on me. is there a correction for this that i am not aware of. i know there is a datalogit software i can get which my car was tuned with here in the states but the tuner had little luck with solving this concern.perhaps its not something he is ccomfortable doing, i dunno. but he had no problem with taking my money to tune my car for a wide open tune which works great....would the datalogit software have the ability to tune the decell which could be my issue.
thanks in advance
Mark
note: if i posted this in a improper location my sincerest apologies
Edited by S14MARKSR
thanks in advance
Mark
this is usually caused by modifying the intake piping
how is the afm setup and what piping setup do you have to the compressor snout?
when you replace the standard rubber item its a common problem as the rubber std item has fins to basically disrupt the airflow
when you replace it with say steel piping or some form of ducting when you come off the throttle the afm signal gets busted up
so i would first check your afm piping and if you can try running with the afm open mouthed, see if that affects the problem
that is - undo any ducting pipe work to the AFM
this is what i am currently using on my car
well as it turns out i wanted to try to add a litle length to the intake like you auggested and to my amazement that did the trick. you sir are one baddass mofo and i thank you so very much for that tasty bit of knowledge. i only hope i dont have to get the car retuned because of it. i did notice a signifigant difference in my wideband readings which are now richer...
no worries - happy to help, its a common issue
a lot of guys replace the std intake piping (rubber accordian style) and it stuffs up the off-throttle and idle sometimes too
  • 3 weeks later...
How can i track the serial number on a PFC to know what type it is?
The only numbers on there are :GTR33 020-0828
is there 2 version's of standard afm pfc's? like old and new?
yeah there are an old generation and new generation - to date we have no known list of differences or what has been changed.
we do know some of the original old old generation use a slow data protocol so when you use it with datalogit it takes ages to make a big change
it still works the same, just the data communication protocol is different, so big updates are slow
that being said i believe you can work out which "generation" you have from the product code (on the side of the metal case)
older generation were ENGINE code specific
ie: RB26, RB25 etc etc in the product code so like - RB25-003204-4536
newer generation were changed to be the CAR code specific
ie: GTR33L-49039-59440 (the L signifies L Jetro, AFM version)
so GTR 33 djetro looks like;
GTR33D-43905-099529 etc etc (the car model forms the part no#, not the engine code)
the same logic applies with the hand controller vesions
FCC1 and FCC NT are the older style hand controller and must mate to a ENGINE code style PowerFC
that is - if you have FCC1 or FCC NT (sold as PFC hand controller N001 or T001 etc) it will only work on say RB26-3493429-93492 it will NOT work on GTR33-490394-5922
the hand controller will boot and panic at the apexi logo and freeze
i believe this is due to the protocol exchanging a checksum packet to make sure its a valid device
and the newer style use a different byte response, so it fails the checksum and panics at the apexi logo
there is no harm done by it, you just can't use the hand controller
if you have FCC3 (which is sold as hand controller X001) it will only work with CAR style product codes
ie: FCC3 and GTR33-49403-324923 will work
hi paul,
i'm having trouble using the stock ecu's brackets to install my power fc. how do i install the power fc ? do i drill holes in the power fc so i can still use the stock ecu's brackets or is there another solution ? the car is a r34 gtr by the way .
thanks in advance for your help
mike
Edited by wanted r34gtr
hi paul,
mike
just use some electrical tape or try and mate it up
or even use cable ties. once the bracket is bolted back in place the ecu cant go anywhere
it will be fine, just as long as the blue loom is securely fastened into the ECU and the ecu is firmly tight in its place
you wont have any issues. i used a few cable ties on mine, but you can use eletrical tape etc as well
hey Paul, nice write up on the PFC..
I was just reading through it, and I couldnt really find out how to set the REV RPM limiter?
I noticed a write up on the PFC Pro - Launch Control, but wasnt too sure if this was the actual REV RPM limiter write up?
Do i just need to go into SETTINGS, REV LIMIT and change the Rev. Limit setting to my desired setting? or is there more to it?
Thanks.
Also I couldnt find anything regarding high/low impedence injectors in the FAQ..
I am in the market to purchase a set of 500cc or + injectors for my R33 GTST, but I read on a website that the PFC does not support Low impedence injectors?
Also, would I need to go and get a re-tune done if i were to install a set of injectors or would the PFC self learn?
Cheers.
    • Can't remember the last time I saw a good, healthy battery dropping into the 9s during cranking,  Too many variables to say anything about it with any certainty though.  A float voltage of 12-12.2 is tired AF and given how AGMs handle high C rate and DOD, will just die faster and faster with each cold start.
    • I find most vehicles dip into the mid to high 9 volt range, even with a good battery. Hitting the low 9s, and especially hitting into the 8s is pretty indicative of a dieing battery. The other part to look at is the battery voltage after the battery has been fully charged. They should be sitting at 12.8V, as lead acids are dieing, they head down low and lower. Often getting as low as 12.0 - 12.2. You'll start seeing this when the engine is cranking over slowly. Interestingly, depending on the vehicle, when batteries get really bad, you can see some REALLY funky things going on. From very low voltages, to higher than 16V too. Something I totally didn't expect! This part of the super low and super high voltages I've been seeing on motorbikes, I need to do some further studies on cars. I suspect cars will act a little bit different though for a couple of reasons.
    • Thanks! Supercheap has a sale on this weekend so might be a good opportunity to get a new one. I do have a decent multimeter so I'll give it a try either way.   Hah, you got me! I do not. All I know is that the battery holds charge and sits at an okay level before I start the car. Doing the full charge and rejuvenation cycle on a trickle-charger seems to not really make a difference to the cold start behaviour. I'll try and measure it during cranking and see what it does. It's likely terrible; it certainly feels terrible.  I'll be happy if it is really just the battery and I don't have to dick around with the alternator or starter motor.
    • how do you know voltage is fine?  quick easy test is connect DMM up and put it on max/min mode, remove fuel pump fuse, crank car for 3-5s, go check min voltage You'd be surprised how many "healthy" batteries are showing under 10v during this test in cold weather.
    • Not properly. You need to be able to dissipate 100 amps or so to doing it meaningfully. You can do it indirectly by watching to see how far the voltage falls during cranking. Unplug the coils or something else to prevent it from starting so you can get a good couple or three chugs. It also helps if you have the multimeter set up reading before you start, and that it has max/min functions. So you can catch the real minimum without having to watch the screen, which often doesn't update fast enough to show the real max/min in dynamic situations. Or use a digital oscilloscope, which can be obtained for <<$100 from Aliexpress (although I'd argue for paying up to ~$200 for a nicer one). A >4 yr old battery will very likely be well down the path to the knackery. Many only last 5-6 years these days. The cold weather lately will definitely make it worse.
