What I read was the pros were earlier versions of pfc and should be compatible with all normal pfc handcontrollers that were manufactured during that period. Like you've said the newer ones has got different model number (415-N001 was the exact model on nengun for the hc). Thanks for the info.
Edited by Brandon
there's a fair bit of work on the BNR32/BCNR33 misfire bug
worth a read if you are still experiencing misfiring intermittently
http://www.skylinesaustralia.com/forums/My...51#entry4767151
Can anybody tell me if I am going about leaning off the cold start on my PFC the right way ? I go to settings, cranking, then in the +10C range I have reduced it from 26ms to 19ms and this seems to have helped as it starts easier but is this correct ? I have also trimmed the other ranges and the car seems to be smoother while warming up. Would I be better off changing the water correction ? Also, what timing are RB25's achieving in the 7 x 7 range before knock ? I have a knock level of 3 in the 3 x 3 range and car does take off better but is that what I aim for then try for more knock higher in the rev range ? Or is 10 or 15 better right from idle ? I just love this tuning thing, though won't be touching the fuel till I get a wide band.
for timing i used the temp ing adjust to add +10 and drove around
kept it under 3 grand and gave it some curry
watched the knock levels and then updated the map from there
see if you can add +5 deg using the temp adjust
and see how you go
but from memory 7 on the RPM axis is 2800 so be careful around here
my 7x7 IGN value is 38
This may sound stupid but how often does pfc/ecu shits itself (due to age)? I'm just paranoid when it comes to purchasing 2nd hand electronics. Would it be advisable to get the boost controller kit for boost controlling or just any aftermarket solenoid with a missile switch? Sorry this maybe a lil off topic.
Ok, I'm looking at my ignition values and at load 3, revs 3 am getting up to 28 ignition value and only 6-7 knock. Seems like a lot of timing but I have added 3-4 deg. to most of the cells so far to get that 6-7 knock. I think it is probably about time I look at a few other peoples timing in that 7x7 area and compare.
Would it be possible for some of you to draw up a grid and plot your cell values ? I'll do mine as I work my way through it and see what I end up with. The car has been tuned by Yavuz @ Unigroup and Hitman so am not worried about fuel at this stage.
Have fixed the starting problem with an increase from 26 to 31 in "cranking" at the +10 range. Seem to be getting more soot spots on the rear bumper though so am wandering if the extra timing is somehow dislodging carbon or fuel deposits from the engine itself or exhaust.
they are solid state devices and the PFC has an nvram chip to save its tune
even with a few months of no piower etc, it won't loose the state of tune
and if the state of tune is lost, which would be unlikely as its nvram, and not a battery backed cache
then you just re-tune it, no mess no fuss
im not aware of any "age" issues with either the PFC or stock ecu
Very comforting to hear that first hand from someone experienced. I've read a lot about the pfc boost controller kit not able to hold high boost well (e.g. 20+psi). For my application I think the highest I would go is 18psi. Do you think they'll be a problem there?
Just wondering if anybody has ever had to replce the screen on there power fc, if so will any lcd screen do and what is the size of the standard screen.
Also if i was to use a bigger/smaller screen would the digits be bigger/smaller or would you just have left over space(on a bigger screen) or cut off some of the display (on a smaller screen).
Im looking at having just the display on the dash with no buttons, that way if a cop ever looks inside it does not look so suspicious.
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#44
Brett: photo pfc1 and pfc2 looks really good! I might do that to the car... lol
Edited by Brandon
OK, currently at LO1-No7 and up to 46. LO2-7 also 46, and still no more than 3 knock. Kept it in that zone and just throttling enough to keep it there and no knock to worry about. Have to tell you though, what a transformation. Instant throttle response. Feels like a friends Honda Integra. Interestingly, vacuum on my trusty Profec B has dropped from 98 on idle to 88, is this normal with 20 in the cells around idle ? I am barely touching the accelerator and it will rev to 3,000rpm no problem.
yeah the part # is in the PFC FAQ, i brought it and tried it but couldnt get it working
i think it needs some form of firmware code on the actual controller board
as its not just a screen, but a complete controller board with a 20 pin connector
so i tried it, and no good
i brought a blue one, with white writing
welcome to try, the part was only $20
but youll probably break your hand contrller trying
I know it's been said before but thank you Paul for the info you have gathered here. I have seen your advice floating around from here to England, Russia, Canada, Hawaii and Trinidad of all places. No thread in the entire forum has travelled so far and been read by so many. Good on you.
hi i just recently bought a r32 gtr that runs a PFC just a quick question maybe a stupid one but if i disconnect the battery its not going to cause the PFC to reset itself ? as i am about 6 hrs away from any good tunning shop
