  • Replies 630
lol terminal i just realised your name is andrew too, IT JUST WONT STOP!!!! j/ks it was a good night last night, although braddon was kinda dead and hume was so dead the only car there was 3 skylines :cheers: ahwell hot chics in a little pink thing kept trying to give us a run, if only neons werent illegal to have on while driving!!! we wouldve looked pimp!!! word of advice.... never eat at RJ's!!! we shouldve gone to chicken gourmet...
Hume was alright last night.......for a little while.
I headed straight there after I left you guys at the Museum, once I got there the police cruiser showed up so most of the bogans high tailed it.
Was an interesting night there, the usual white 180sx, red VRX and silvias showed up.
As well as Alex in his brand new R33 GTST.....it's that dark green/bluey colour so give him a wave if you see him around (southside).
No one did anything as the unmarked red HSV was sitting right next to us all. Still good to have a chat with like minded enthusiasts.
Didnt get to the museum till about 11:30 and no-one was there so we went to civic for a feed. Spotted a silver series 1 out the back of the old car park and also The Sandman havin a feed at Ali Babers. Maybe next time Im up that way i might get to meet ya's.
did you just say silvias??? omg i cant believe i missed it, were the majority S13's? what time did you get there? cause andrew and i got there at like 11.30-12
Two S13's.
I got there at about quarter past ten. By the time you guys had shown up we would have moved onto a different section of Hume. Some nutters on dirt bikes were provoking the police there so we went somewhere else to chat.
lol,
cmon ppl come out tonite!!! shaun u shud be there so i can take pics of ur car, the last and only time i ever saw it was at the pub on tuesday!!! and same goes for u andrew (veilside) i wanna take pics of ur ride before u sell it.... memorabilea (i think thats how u spell it)
Hey guys,
I was just wondering if there was anyone in the northside(eg gungahlin) that hasnt left yet who would like an extra passanger? I'd love to come and meet a few of you guys and gals and see your rides. I should be getting mine soon, but would love to head out for tonight if someone is able to help me.
Thanks,
Nathan
Woops my bad! I'm northside and would have had no objections to taking a passenger! Only problem is... I just read this now!!! Any one cruising tonight? I just had my car cleaned "full valet"
Damn they cleaned it good! Its even got a new car smell about it! lol.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
