  • Replies 630
Damn - a sound off. Oh god why have you forsaken me...lol
As someone else said "I love it when my Stez makes your door trims rattle".
Show off
JVC CD/MP3 Head Unit
Pheonix gold Splits (6"x2 plus tweeters)
Boston 12.5" subs x 2
Fibre Glass Custom Mould boxes
Orion Xtreme 800w amp
Orion 250w amp
Fluro's
Capacitor
:bananaman :rave: :headbang:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
