Recently picked up a set of Reverse El Dials for my R33 gts25t,
Was wondering if they are hard to install yourself, are there any DIY guides to it?
My Guess;
1. Take off console/dash
2. Remove Dials/clusters
3. Slip the reversel dials over the originals ones, and connect power to somewhere (err.. cigarette lighter power?)
4. Put everything back together
Can anyone thats done it themselves before assist/guide me, didn't get any installation instructions so its all by GUESS.
the same dash console area (speed dial, tacho, warning lights etc) area
you can get reverse el dials set which is the same console unit but it in a cool fluro blue nightish psycho flurosecent colour insteae of just the stocker white lit colour
Anyone HELP with installing them??
Refer to this page....
http://www.skylinesaustralia.com/forums/sh...10&page=8&pp=25
I did it myself, the hardest one is the fuel/temp/speedo section...
Basically pull off the gear stick surround, remove the dash surround, steering wheel column covers & unplug all the wires going to the Mirror control, clock, air con unit.
Undo the 4 screws, 2 which are at the bottom of the cluster surround, then 2 at the top which sit vertical.
Remove the surround, then undo the 3 screws holding the cluster in. One in the center, and 2 either side of the cluster.
Unplug the 2 electrical leads running to hte cluster, and the whole thing will come out.
Remove the clear lens. Very easy as it just unclips, same with the black surround. Once black surround is off, you should know where to go from here.
The tacho will need to be removed to put in the factory boost gauge EL dial. Make sure you dont bend the dials as much as you can, cause if they warp, you will find that the needle catches on the tacho or speedo.
Hope this helps...
Thanks Mr_G, i was looking for a responsee like that,
i've had my Skyline for 3 years and never been happier, with forums like this one wif DIY guides,the friendliness and helpfuliness of fellow forums members..
I THINK ITS TIME TO *!DONATE!*
If you get very stuck, you can always pop round or something and im more than happy to give you a hand taking the car apart...
When you thread the speedo/temp/fuel section wiring through the hole, you will need to cut the wire so you can feed it through, as the clip on the wire that goes to the control unit is to big. Cut it, resolder once you thread the wire through & dont forget the heatshrink or electrical tape to seperate positive and negative.
:P
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
