Recently picked up a set of Reverse El Dials for my R33 gts25t,
Was wondering if they are hard to install yourself, are there any DIY guides to it?
My Guess;
1. Take off console/dash
2. Remove Dials/clusters
3. Slip the reversel dials over the originals ones, and connect power to somewhere (err.. cigarette lighter power?)
4. Put everything back together
Can anyone thats done it themselves before assist/guide me, didn't get any installation instructions so its all by GUESS.
the same dash console area (speed dial, tacho, warning lights etc) area
you can get reverse el dials set which is the same console unit but it in a cool fluro blue nightish psycho flurosecent colour insteae of just the stocker white lit colour
Anyone HELP with installing them??
Refer to this page....
http://www.skylinesaustralia.com/forums/sh...10&page=8&pp=25
I did it myself, the hardest one is the fuel/temp/speedo section...
Basically pull off the gear stick surround, remove the dash surround, steering wheel column covers & unplug all the wires going to the Mirror control, clock, air con unit.
Undo the 4 screws, 2 which are at the bottom of the cluster surround, then 2 at the top which sit vertical.
Remove the surround, then undo the 3 screws holding the cluster in. One in the center, and 2 either side of the cluster.
Unplug the 2 electrical leads running to hte cluster, and the whole thing will come out.
Remove the clear lens. Very easy as it just unclips, same with the black surround. Once black surround is off, you should know where to go from here.
The tacho will need to be removed to put in the factory boost gauge EL dial. Make sure you dont bend the dials as much as you can, cause if they warp, you will find that the needle catches on the tacho or speedo.
Hope this helps...
Thanks Mr_G, i was looking for a responsee like that,
i've had my Skyline for 3 years and never been happier, with forums like this one wif DIY guides,the friendliness and helpfuliness of fellow forums members..
I THINK ITS TIME TO *!DONATE!*
If you get very stuck, you can always pop round or something and im more than happy to give you a hand taking the car apart...
When you thread the speedo/temp/fuel section wiring through the hole, you will need to cut the wire so you can feed it through, as the clip on the wire that goes to the control unit is to big. Cut it, resolder once you thread the wire through & dont forget the heatshrink or electrical tape to seperate positive and negative.
:P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
