maybe without the music it would make it better....
i wanna hear more engine/spool/exhaust noise...
if thats "only" 380rwhp then its making me grin like a little girl
id be tempted to buy your car too :rofl:
yea i later figured out how to change the volume in little segments to late on and I couldnt be bothered making and uploading another one with it...meh, much better gear to come nyway...
https://www.sau.com.au/forums/topic/64580-r33-vid/#findComment-1209348
he had it ages and ages ago, even before you i think melv ;)....and yea he knows its a trust one :rofl: I dont have any more vids of his car atm...But rest assured after a weekend or too there will be much better footage.
https://www.sau.com.au/forums/topic/64580-r33-vid/#findComment-1209726
we want street races and footage of trying to get away from the cops, but getting tyre spiked and then bent over the bonnet while a long line of Qld's finest take their turn
That’s in Humorous ruckus video vol.1.2, where I don’t value my 1-point, and do silly shit.
Also the M1 is really a highway in Stockholm, and I’m practicing for the Gumballs run.
https://www.sau.com.au/forums/topic/64580-r33-vid/#findComment-1210631
rofl, should i bring a camera tonigh???
https://www.sau.com.au/forums/topic/64580-r33-vid/#findComment-1210813
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
