Went down to WSID for my first go in the Skyline - Was interesting....
7:15pm
60ft - 2.146
MPH - 105.5
ET - 13.321
8:11pm
60ft - 2.206
MPH - 106.81
ET - 13.391
8:23pm
60ft - 2.186
MPH - 108.73
ET - 13.367
9:02pm
60ft - 2.219
MPH - 104.61
ET - 13.332
9:53PM (My mechanic said that I cant drive my own car and I should let his mate drive it as he is a awesome driver)
60ft - 2.374
MPH - 107.97
ET: 13.558
-At this point I was convinced that the car was only good for low 13's and that I should be happy so I decided to try and take off the same way I do on the street.
10:08PM
60ft - 2.012
MPH - 107.30
ET - 12.978
12 SECONDS BABY :lol:
10:21pm
60ft - 2.015
MPH - 108.01
ET - 13.182
R33 GTST - RB30DET - Custom turbo (not bug at all just a turbo i put together with old bits sitting around) PFC - AVO Stage 2 cooler - HKS Dragger zorst - Stock injectors Walbro 500hp pump - water sprayers on cooler. on 9PSI of boost.
https://www.sau.com.au/forums/topic/64871-wsid-results-wed-16th-post-yours-up/
What tyres were you running and size, pressure???
I think you would run lower 12's if you decrease your 60 foot by a bit. Also I hope they did not let you run the water sprayers on while you did the run...that is just stupid!!!
And I am guessing that was with a bit of wheelspin considering the torque that engine must produce
Standard Nankang street tyres on my mags 235/40/18 with 20psi pressure - The water sprayers were on - they dont leak onto the ground - very small misting nozzles from the states - got them from a guy on this forum actually.
The run where i got a 12.9 was NO wheel spin. got a good launch - Clutch slip launch
18's??
try it again with a set of 16's and 225's with 20psi air in them.
I'm sure you could get it better..
hmmm..
in my S14 I was launching at 4000-4300rpm and that was best for me with heavy'ish 17x9's and 255's.
anything below 4000rpm and it would bog, even with slipping the clutch..
anything above 4300rpm would require backing off to get traction.
I raced, my first run was my new PB (not by much tho, down from a 14.145 @ 102mph). The next 2 runs were sloppy so I parked it for abit to watch all the PAC Rotory cars and heaps of other cars. Next think I know it's 10pm and i'm driving out the exit gate
14.009 @ 102.07 / 2.089sec
I also managed a 0.035 R/Time too which is my PB.
I was in full street trim (minus my subwoofer). Tyres (225/50/16) were still at 38psi too but I need some Nitto's now :/
I'd say without a doubt the best nites racing in a good 3mths or more... can't wait until it's winter again !! I'm still far from happy with my times but i'm still improving each week so i'll be back again.
  • 4 weeks later...
finally got to to to the street meet for the first time!! it was a good experience but disappointing! I had only 2 runs before the rain. first run i got bogged a little and my clutch not holding as well, and only managed 13.69s @ 108.7mph & 0-60ft 2.4s!!! well my second run i tried to launch at higher rpm (5500rpm) and riding the clutch but then my clutch (pressure plate) just gave up and got stuck half way! :cheers: getting my clutch replace this Saturday!!
will be back when i run in my new clutch!!
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
