Its not so much the power but the amount of Air that it can measure. For example a HKS GT-RS will make a certain power level at 14 psi and a standard turbo will make a bit less power. What I am trying to say is that I think the rb25 AFM will max out at about 14 psi. Now depending on what turbo you have your power levels at 14 psi could be anything from 180rwkw upwards.
If your rb25 has a stock turb then the stock AFM should see you to about 200 rwkw...
hope that makes sence :)
my airflow meter maxed out at 12psi and i was making just over 200kw
there are alot of things that you have to take into acount
you have to remember that hot wire air flow meters work by heating the little wire in side, when air passes over it, it changes the resistance in the wire so it takes more voltage to heat it and thats the signal that is send back to the ecu. once the voltage reaches 5.13 volts it cant heat the wire anymore and that is when you are maxed out
air density(temperature) plays a big part in this as colder air will cool the wire easyer
that i why mine maxed out at around 12psi and some of you guys can run up to 14 psi without a problem
i hope this has helped you
what symptoms would you have if your air flow meter was being "maxed out"
like if you didnt have an FC with commander telling you exactly whats going on. how could you tell?
Cheers
if your running a standard ecu it feels just like your boost cut and if you havnt hit that yet, it feels like your going to be thrown though your front windscreen, its a very sudden jolt. thats the best way i can explain it
I changed to rb20/25 afm's on my GTR becuase the std ones ran out of head room. I'm running 2530's at 1.2bar with rb25 afm's(same as rb20) and I more headroom then I need . Much cheaper option then z32's and the rb ones just plug straight in .
that's what he want's to hear :cheers:
to others he's talkin twin rb20/rb25 afm's on a gtr
This is from Sydneykid
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Your Engine warning light will also flash in a particular sequence when your AFM maxes out. This is often mistaken for knock... I am not sure what the 2 different sequences for knock and AFM Max out are though...
Is their a way of checking if the stock AFM is maxing out? without using an aftermarket ECU?
Sure can mate. if you have the car on the dyno the output voltage can be checked using a multimeter. anything over 5volts and the AFM is near max. infact with a pin out diagram you may be able to check what voltage the AFM is sending to the ecu (thus not needing to check it in the engine bay), this way you could check it on the street/strip instead of having to use a dyno.
  • 3 years later...
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
