Yea they do look good. Surely there no difference in front gaurds except for GTR gaurds are wider yea? Looking at buying CF GTR grill, CF eyelids, and GTR indicators atm. Wasn't sure on clear indicators and not a fan of the smoked style. Grill should fit. I got GTR style CF bonnet with same nose as one in pic. Not GTS-t where nose dips between headlights.
EDIT: If you buy a gtr copy bar for a gtst you wont need the gtr guards but if you get a genuine gtr bar you will need the gtr guardsthumbsup.gif
Well actually , a factory gtr bar fits better than the fibreglass gtr-gtst copies that i've played with , the only issue i've ever had with factory gtr bars is that they stick about 1cm into the wheel arch which can be fixed with a little plastic welding . i've fitted 2 copies and both of them stuck under the headlights at each side from being too narrow , which is a c**t to fix properly
That 32 4d looks tuff , makes me want another one! :ph34r:
agreed. i got a gtr copy bar and its 30mm out and didnt even fit over reo bar.. was so annoyed and couldnt be f'd glassing it to fit so sold it
i contemplated 34 front ;) but thats not quite targa spec lol... personally, my old kit, Do luck kit is the best 32 kit ive ever seen.
Yea I have a GTR style cabron fibre vented bonnet and headlights say R32 GTR (doubt there any differenceto GTS-t).
Oh and Funz...I have a Do Luck kit :P
Front bar pretty drift spec and rest of kit pretty shabby so want to get another Do Luck kit. Dunno how I will go with allignment getting 4 door skirts and rear bar with GTR front bar if I get GTR gaurds.
Hey Guys!
Just thought ide get a little sentimental and congratulate you all on being good guys!
its refreshing to read these forums and finding everyone getting along, helping each other, not bitching about other people and businesses.
Boostcruising.com seems to be full of it!
im getting all teary and shit :' )
Good work :)
Ant.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
