Hey Guys!
Just thought ide get a little sentimental and congratulate you all on being good guys!
its refreshing to read these forums and finding everyone getting along, helping each other, not bitching about other people and businesses.
Boostcruising.com seems to be full of it!
im getting all teary and shit :' )
Good work :)
Ant.
You should stop wrecking that R33 and join us in our complete and utter awesomeness at the track day :D but yeah, I agree it's really nice to see a forum where not every post is having a go at the post directly above it. Nice place to hang out :)
Haha, the R33 has had a pretty hard shunt in the front end, better off parting it out!
but maybe i can hang out with my baby skyline?
its a onevia but has a 26/30, so its half way there :P
when is the track day? maybe Funz will let me take his out :D
The track day is on the 12th (next sunday), there's a thread floating around on the first page somewhere. Would be good to see you there, been trying to get Kyle out there as well but since those f*%ks torched his car I don't think there's much chance of that :(
You can bring what ever you want, some dude there last time had a Starion :P Plus it'd be great to meet you.
You should get the Wreck Broomhall has which has a shunt in the side and combine them! lol pirate.gif
Edited by zoidbergmerc
you put that 33 diff in my car and i might let you drive it, if you pay for fuel.. and both our entries mwuahahahaha :P
your 26/30 should be in my car.. swapsies of engines? fair deal i say :D
not sure where to ask so ill ask here, dose anyone know how to get paint off a stainless intake plenum/manifold (what ever you want to call it )
old owner painted mine rattle can black & it looks crap, i want it back to stainless but don't want it scratched
cheers
Edited by Autumn33
cheers
Thinners in a small bucket with rags is far less messy than paint stripper :wave:
problem solved! it seems the warp speed button was flicked to *engage*
na but seriously, vent holes in my bonnet were letting way too much water (pissed down yesterday) hit on my airflow metres causing the power fc to say shutdownski
knew it would be something like this
been reading up on here about remapped R33 ecu's ( at this time i cant afford Power FC/ haltec, ect
i know dr drift dose them ( you send him your ECU & list of mods done & he remaps to suite ) just wanting to know if anyone in tas like GT garage ect do it?
cheers
Edited by Autumn33
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
