interesting info, and 6k for a manual conversion is alot of cash, but selling the stagea with it manual will sell in 5 sec's flat cause they are rare, dont know about getting the 6k back in resale but who builds cars for profit? :O
a r33 gts-t handbrake fits and needs to be custom mounted to the body as there is no holes already there or nuthing, and even a thick plate should be welded onto the bolting up area as its only thin metal in that area and after a while it will deform the floor from the pressure on it from the handbrake cable being pulled tight all the time.
im after a console but 1000 bucks is alot imo for some plastic bits.
i used an Autech pedal (can be ordered through nissan i think), and pedal box is just a gtr one i think (99% sure).
mounting the clutch vacuum booster is the biggest job if u want it to have a light feeling clutch pedal, and with the engine in i wouldnt attempt it personally.
the joys of changing things :O
good luck what ever u decide alex ;)
cheers
Brad
  • Replies 297
My car, like Cyrus', has an R32 GT-R box too (but no PowerFC, dammit!), so I doubt you'll have issues there if you still decide to go ahead with it Alex. Also, I don't understand where the different ratios (4.11 in the R32 GT-R vs 4.3 in the Stagea) would cause a problem, aren't these just diff ratios anyway? I'm sure the only thing you'd need to worry about is the transfer case, which is probably the same anyway (although I'm only assuming)...
I've gotta say, I love my car especially because it's a manual. If I hadn't found this car I would have scrounged a bit longer and harder and waited for a Series 2 RSFour S. Tiptronic just doesn't come close enough for me...
cheers
Brad
I was told this too when I bought the car, the previous owner was the one who did the conversion and he stated that reinforcements need to be made up around where the handbrake is mounted so the body panels in that area don't bend over time...
the auto tranfer case is totally different to the manual gtr one, as the gearstick actually comes out of the top of it and in the auto it doesnt have the hole. plus the gtr one is alot tougher and internals are alot stronger and heavy duty while the stagea auto one is only a cheap version with weaker parts.
There you go! I've never had the opportunity to get the two gearboxes and transfer cases together to check, but now I know.
Brad, question for you: I'm not too worried about blowing my gearbox, seeing as GT-R boxes are a pretty well-known quantity as far as strength goes, but how much abuse will my driveshafts take? My car was fitted with a six-puck clutch when the conversion was done, so I seriously doubt that will be an issue until wear starts to set in, but I've never done a hard "drop the clutch at 4500rpm" launch, because I'm scared of snapping driveshafts and/or CV joints.
There's so much grip, too, that even if I try and slip the clutch with maybe 3,500 to 4,000rpm, it bogs down anyway and comes off boost. I wanna be able to stay on boost, but not risk snapping the shafts or joints.
hey mate, well its hard to say, as mine might have snapped because of a manufacturing fault, or maybe it had been shocked hard previously in an accident or something, and the fact i took off from a set of lights from idle, and then just floored first gear once i was rolling along and as it hit boost it just went bang and i tried to go into 2nd gear and the car wasnt moving, which i thought was the gearbox or the tailshaft at first, until later inspection. i think the rb26 nature is alot laggier and then bang it hits boost, where as the rb25 is less laggy and more linear meaning less shock on the driveline. i had roughly 350-360rwhp at the time it broke, but just a quick and very important note is the car was in 2wd only and with the non-lsd diff it was trying to push the cars weight through only one wheel and that may have been the main cause. i also had 4 people in the car which would have been 1800kg for the car plus 4 peoples weight so around 2100kg of weight is alot to move with one tiny axle :P
the gtr shafts are huge in comparision and even r33 gts-t's use the gtr size shafts and uni joints.
if u want to know in more detail i posted a thread in the stagea section on the gtr diff conversion, and i dont want to go off topic in here or it might upset the moderators.
cheers
Brad
Thanks for that Brad.
I do remember that thread, now that you mention it... I might have to scan back over the old threads and compare shafts according to your findings...
Cheers,
Nick
If anyone is looking at purchasing the manual console parts i've listed, i'd urge you to hold off until i confirm something.
I've since found out that Part number 96920-0V800 Lid-Console Box, could also include parts, 68643-6P000 Bumper Console and 969A1-0V800 Tray Assy, in which case you would only need the one part number for all three items.
I'm waiting on 100% confirmation on this and should have it within a couple of days, if it is the case the price would be even cheaper than i quoted previously.
Hi Terminal,
I should be picking up our new Stagea this week, after going through compliance. Mark suggested we should get together when he gets back from a short break. I was really impressed with the Tow bar you got done...very schmick.
I am driving it back from the Gold Coast, so should give me an opportunity to get acquainted.
Good luck with the manual conversion.
i won't have it converted for about another 3 months, i'm going to take my time and try to get all the right bits first.
I drove mine back from the gold coast when i bought it over a year ago now, but i managed to get 2 small stone chips which took 8 months and $850 to repair. be careful is all i can say.
I intend to go back via the coast road, about the only worry there is around where the road works are on the Coffs coast. I will be taking it pretty easy, as I am sure that it could do with a nice long run. I intend to use only Premium, and will slip in some injector cleaner too.
Not sure what size tank I have, but from other threads, looks around 400k's per tank.
I've decided it might be a good idea to hold off on posting the part numbers until i receive my order and confirm that everything needed is there, i've talked to nissan about a couple of the parts that are supposed to come as a package under the one part number, and they're 99.9% sure that they do come as a package.
So before i quote anything again i just want to make sure :D
Should receive the goods in bout 2 or 3 weeks and i'll post the results.
i've been talking to a guy who imports stagea's and he mentioned to me yesterday that he knows someone who will do a manual conversion for $3k
just though i'd let ya's all know...i can get details if anyone's interested
Im interested! :) Well actually, Japlink said they could do it for $3000
Is that just for labour? i'm assuming it is. With all the parts needed you would be looking up around the 5-6 grand mark roughly.
well thats the quote they gave me drive in drive out...
But you would probably find that they are way off
Would that include the interior parts too? i don't think you'll find too many places willing to source those, sounds like Beastian went through a bit to get hte ones for himself
  • 4 weeks later...
I received my manual console parts today, Hooray :D
So i've re-posted the part numbers in my previous post, all parts are confirmed.
I'm still going to use my rear ashtray because it's identical to the one used in the RS4S, the front ashtray however is a different coloured silver, the old one fits but it looks a bit out of place, i've posted the part number for the RS4S one in my previous post aswell.
The grand total came to just over $1000 (i was hit by customs, and got quite a shock :) ) but this is still alot cheaper than you'd pay through Nissan Australia.
Everything was quite easy and smooth (except for dam customs) so no one should have any problems.
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
