um, why would you wanna put 235 on the front and 255 on the back?
255 is supposed to go on 9" wheels and
235 is supposed to go on 8" wheels
It's not that you can't fit it on (you could probably squeeze on 275 if you really wanted to), but basically, it's just too ridiculously big for the wheel. You'll get the sidewalls crazily floppy, and the tyre might rotate on the rim.
This is what I reckon is a good width:
6.5" (r33/r32 gtst wheels) - 205
7" - 205 or 215
8" - 225 or 235
9" 245 or 255
If you want firmer tyre walls when cornering etc, i would not go for 235. If you put on a 235, the tyres will be a bit wide.
If you look at a 225 on an r32 gtr wheel (8"), the tyre walls are perfectly straight up and down. That's how I like to run it.
so for the gtt wheel, i'd probably put a 215.
But say for drags, it's different. Having a wider tyre is better, and you don't have to worry about lateral movement of the tyre, so putting a 235 on would be good.
Ok so 235/45/17's on all 4.
4.6mm larger sidewalls won't be much of
an issue will it?
This is assuming the compliance place
will let me put on non-standard tyre sizes.
Otherwise itll be the stock 225/45/17 all round.
Thinking about Hankook K104's, had Falken ZE326
last time - hopeless in wet.
ECL - Do you have any Traction contol problems (TCS) or do you turn it off?
I had 235/40-18 front and 255/35-18 rear and the TCS could see that there was 1inch difference in Circumfrence and activated the TCS over 80mph
I changed the rears to 265/35-18 and solved the problem (1/3rd of an inch difference which the TCS can't see).
info from - http://www.miata.net/garage/tirecalc.html
I think you might find that the width is not the problem here only the rolling diameter. Think if it logically for a larger diameter (55 profile) to complete one rotation it will have to be rotating fast then a smaller diameter (45 profile). Seeming both are traveling at the same speed (unless traction has really been lost) the small profile wheel will complete a rotation before the larger therefore the ECU calculates this as a lost of traction hence the TRC warning light and related issues.
I hope this helps.
I know that this doesn't stay true for eriktufa's case, I have no idea why your having troubles your 45s shouldn’t confuse the system at all.
Someone please correct me if I'm wrong,
Sully
I have 8 inch rims on the front, 9 on the back.
I run 235 on the front and just recently changed to 255 on the read, previously 235 stretched to fit.
Didn't have problems before and don't have problems now.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
