Sorry to the mods, but being that all these parts are specific to cefiro's and laurels i thought it would be benefincial to post this here..if you need to move then no problem
I have a few cefiro/laurel parts lying around that i am wanting to get rid of. I can barely walk into my shed anymore.
cefiro parts:
Front and rear standrd bumpers
Cefiro floor mats (genuine) i have a couple of sets of these.
Dash surround
Air-con control unit (the part with the buttons on the dash)
Black carpet in good condition.
Velour roof lining (grey) could do with a clean but has no tears etc.
Dash cluster (odometer spins freely since accident, not sure if speedo works)
Cefiro/laurel interchangable parts
Passenger side LEATHER seat.
Electric aerial
assorted interior pieces eg: dash surround bits
MAKE OFFERS ON THIS STUFF I NEED SOME ROOM!!!
I have other bits that i have forgotten too........if you are after something specific just let me know and i will see if i have it.
Give me a call on 0402 807 417 if you have any questions etc.
Cheers
Dash surround bits!! bags it - will call now to explain since it's a little hard to explain in text.
Sold - the air con vents in the middle of the car and the little air con vent that points at the passenger side mirror.
FYI to everyone else he doesn't have the passenger vent surround that everyone seems to be missing, nor the right hand side little air con vent that everyone sticks a gauge into.
SHOT GUN Air-con control unit (the part with the buttons on the dash)!!! $20??? Or tell me if Im dreaming.
PM as well.
And if you dont read that, I'll come down on the weekend whenever your most free!!!
I'll also look at the floor matts.
Carpet.......$70 ......Plus postage,due to the size i ask that you organise frieght, I am happy to drop it off at the Gold Coast depot.
Aerial may be sold...will let you know if it falls through.
Anyone else? I have a few mech parts too eg: coil packs etc etc
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
