  • Replies 288
Hey, let's see if I can get this thread to ten pages before someone actually buys one.
If you can get the 2530 with a T3 flange (i have done a bit more research and they do come with either the T2 or T3) for $1900 I will definately be getting one off you soon, just need a few more weeks to save up ;)
I know 100% that the 2530 is avail in a T3 for the HKS model but I don't know for the Garrett version. My rep is finding out for me tomorrow as I asked him this afternoon.
There is Garrett USA and Garrett Japan. I think there are a few more but they are the main ones. All of our stuff comes from Garrett Japan.
There are a few differences between the Garret range from USA and Japan also so you have to be very careful of what you read on the internet as it may be misleading.
i thought garrets made in usa?
So I can't get one for my R34 that will be direct bolt on? what type flange does it come in?
That should be a direct bolt on. It is the T28/T25 style flange which a am 90% sure the 34's have. I cannot find out from anywhere so you'll have to check.
Do your contacts Mix and match compressor and turbine housings?
When i spoke to horsepower in a box they were mixing and matching them,garrett (gt2535)_(2530) etc with t3 and t25 exhaust flanges.
And also offering a 500hp compressor cover with either .64 or .82 and carterige to match.
So it is possible,but,morrie gets them matched by a turbo company.
Guest 3LIT3 FORS3.
They can mix and match, they have a full engineering workshop. garrett are about to release all of those turbos with the T3 flange so we are pretty much just waiting for it to happen
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
