Hi guys i just bought a r33 series 2 turbo for my r32, just wondering how much it should cost to get it put on,i have rang a few places most are charging around $450 which i reckon is way to much? what does everyone think. Option 1 quoted me $350 but i have found them to be a little interesting when it comes to doing a good job!.Any help on where to go for a reasonable price would be great. Thanks Josh.
https://www.sau.com.au/forums/topic/66574-turbo-install/
As everyone knows i used to own a fully sick HR31 (thorpy said so)
I changed from a standard unit to a r33 s2 turbo. The whole process is remove old turbo and put new one in. The only thing is you need to use the R31/32 top oil feed line as the R33 one will not bolt onto your block. So use the R33 water lines as their bigger (4mm internal) and use your r31/32 oil feed line. The exhaust dump pipe will bolt straight on and the air intake pipe is the same size.
It took me about 3 hours actually to be honest as i had rusted bolts on the exhaust dump pipe so i needed to pay more attention to that.
Do it the easy way, remove the 6 bolts from the back of the turbo and remove the whole dump by unbolting at the cat. One big piece. Remove all the heat sheilding crap and leave it off as it sucks ass.
Hey if you want ill do it one sunday for $350.... LOL
https://www.sau.com.au/forums/topic/66574-turbo-install/#findComment-1239795
Thats another way... Just depends on spanner swinging room....
Do it want ever way you want... but dont pay over 150 bucks for someone to do it....
Yeah pretty much hey, because it would seem most workshops charge $66per hour... So that would work out about right, as they should be better at it as they do it more often.
https://www.sau.com.au/forums/topic/66574-turbo-install/#findComment-1239921
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
