  • Replies 85
Hey Fatz got any witches hats,,,I might bring the Pulsar out,,,.
We could actually see how good some of you are at Motorkhana and then if any of you are good enough you can back up on Sunday and do the 1st round of the NSW championship.
Neil.
neil yea there will be a timed motorkana section for a bit of competition
tash- get out there i need to still fill a few numbers
merli- it can be as wet as you want but you will have to drive the water truck mate and or help with the hose
if you want to confirm a spot make sure you put give me a call casue first in best dreased and it getting very close to full
so call me
0409226626
pete
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
