Hey guys
Just a post to let you know that the Nissan/Datsun Sports Owners Club is holding a drag day at Heathcote Park on the 28th of May (its a Saturday).
Entry is open to all Nissan/Datsun vehicles and you don't need to be a member to enter the event.
There are numerous classes to cater for a wide variety of models, so there is something to suit everyone. The finer details of the classes are still being finalised.
For more information you can email contact(at)mazdarotary.net for an information sheet which will be available in the next week or so.
Thanks!
Ben
  • Replies 71
Further info/details:
General Event Information
Date: Saturday May 28
Time: 11am to 4pm
Location: Heathcote Park Raceway (www.heathcoteraceway.com.au)
Costs: $40 To Race, $10 To Spectate
Facilities: The club will be holding a BBQ, although a canteen is also open at the track
Contact Details: Matty ([email protected] / 0414 726 692) or Ben ([email protected])
PLEASE NOTE: In order to allow more efficient organisation of the event, please confirm your entry to one of the above organisers by May 7
Requirements for Racing
Long Sleeved shirt/pants
Helmet in good condition (Helmets are also available for hire at the track)
Radiator overflow bottle
Car must be in safe/roadworthy condition
Passengers must comply with the same requirements as drivers
Class Information
Note: All classes DYO except Top 8, minimum entry numbers apply for each bracket
Classes available:
- Zed Challenge: Two classes - Classic (From 240Z to Z31 300ZX) and Modern (From Z32 300ZX onwards)
- Skyline Challenge (All RWD & 4WD Skylines except GT-R, Turbo and Non-Turbo)
- Silvia Challenge (From S12 through to S15 (inc 180SX))
- GT-R Challenge (R32-R34)
- Race (Open to any vehicle, slicks, race fuel, no exhaust)
- 4WD (Open to all non-Skyline 4WD models)
- RWD (Open to all non Zed/Skyline/Silvia models, Turbo and Non-Turbo
- FWD (Open to all FWD models, Turbo and Non-Turbo)
- Female-Only (Open to all models, female entrants only)
- Top 8 (Open to quickest 8 cars of the event)
Further details on classes and the event information sheets are attached.
  • 1 month later...
I'm pleased to be able to announce that we have also managed to secure a couple of the fastest Nissan's in the country for this event. Coming over from South Australia are:
Theo Spartalis' GT Autosound S15 Drag Car ( http://www.gtautosound.com/projects2.php?s...section=s15drag )
Keir Wilson's two R32 Drag GT-Rs ( http://www.ausautoportal.com/willall/draggtr.htm )
With just over a month to go, the event is shaping up to be a real treat for Nissan/Datsun fans.
Remeber for more information please email contact'at'mazdarotary.net
Replace 'at' with @ (to prevent spam)
Thanks!
Ok - who we got so far?
Snowman
R31Nismoid
riggaP
Adzmax
Al (?)
West
Robo's
Leewah - 617rwkw's
PurpleR32 - 535rwkw's (your coming Rosco)
Who else? It's cheaper than Calder and you'll get more runs here.
you can enter on the day, thats no problem.
Entry doesn't have to be confirmed early, but it can help to organise things a little better and get an idea of the number of cars per class etc... :D
heheheh, well if i dont break my box either this weekend or next i will try to get there.
Would be great to run against Keirs car.
It outta my hands and upto the gearbox gods now :headspin:
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
