i need your help guys. I dont know why but im only running on three cylinders. heres what happened. Yesterday i decided to buy some oil to service the car today. So this morning i went out too the car and take it fora drive to warm up the oil abit. But when i started the car i noticed that it had the distinct sound of a modded wrx with alot of vibrations going on in the engine bay. Immediately i suspected a failed/disconnected coil pack - which i just replaced not long ago. So i opened the bonnet and fiddled with the coil packs. Started the engine again but the noise and vibration was still then, as the engine was running i disconnected each coil pack to see if any had failed. It turned out that coil pack in cylinder no.2 looked to be failed but as i didnt want to spend money on another coil already i switched it with another coil in a different cylinder. I started the engine again but with no luck cylinder no.2 still wouldnt fire no matter what coil i packed in there. So i tried disconnecting the injectors while it was running and again only cylinder no.2 would no responded. I recently had a compression test and all was around 160. What could the problem be, i havent tried fiddling with the wirning harness for the coil packs yet but im stumped. Its a long post but i didnt know how to explain it any better. Any help is very much appreciated.
Only other thing i can think of is what you mentioned at the end of you'r post, sounds like a fault along the wiring harness.
Is the bad idle the only symptom or is their smoke pouring out of the exhaust, does it drive/ missfire at a certain rpm?
prior to this it idled quite roughly with misfires here and there. It also stalls occassioanly when rapidly decreasing speed ie stopping at traffic lights. Now that i cant get spark/fire in the 2nd cylinder the engine visibly shakes. Someone please assure me that compression isnt down on this cylinder and its stuffed.
Ive had the worst luck since purchasing this car. Just when im going to change its oil this had to happen. As i mentioned before, engine shakes as it runs on only 3 cylinders. i think im going to have to get a compression test done again.
When I had a similar running in my RB20DET, turned out I had spat off a chunk of piston that, among other things, hit the end of the spark plug and closed the gap to nothing.
Pull the plugs, and check they're OK.
Check the usual first; Make sure you don't have any vacuum leeks for starters.
How old are the spark plugs? Maybe try a new set of plugs.
Go though and check the coils, look for burn marks / Cracks, anything that doesn’t look normal.
Do you know any one else that could lend you a working set of 4, that you could test?
Check the connectors on the Coils and check the connectors on the injectors?
Also what mods have been done to the car? Eg is it running standard injectors, Is it running an Aftermarket ECU?
If it’s still running on 3 cylinders after changing the plugs and a fresh set of coils, get a leek-down compression test preformed.
See how you go.
Ive recently replaced a cracked coil pack. Im sure none are faulty since i repalced the crakced coil pack as i have ran the engine on while cycling through the coils on each cylinder and only the 2nd cylinder that doesnt seem to respond even when i unplug the injector harness on that cylinder. As for plugs, I havent had the plugs changed since it was purchased although upon looking in the spark plug hole/cylinders there appear to have alot of build up of dust. I have a tool to remove the splug plug but havent been able to remove them yet as the extension isnt long enough.
The only mods that i have are fmic/full exhaust/bosch fuel pump/aftermarket radiator and bov - plumback. ecu and injectors im sure are standard along with anything else that hasnt been mentioned.
Simple and cheap to fix? matt, can you have a look at it for me as it would be very much appreciated.
Yeah sure mate, I can have a quick look if you'd like. What suburb are you in?
The first thing to do is pull the No2 plug and replace it. By the sounds of things it may well be as simple as a damaged plug (electrode and/or ceramic) either that or the plug is so badly fouled it won't fire.
I've got a whole stack of new BCPR6ES's and 7ES's, and even a set of six 8's, so if the SR20DET uses the same style plug then you don't even need to bring a plug :(
If it isn't the plug then we can go back over the coil and injector side of things. Don't stress that it's a internal engine issues just yet matey :D
im not stressing that its any internal damage to the engine although my post may come across that way. Its just that ive had one problem after the other since ive had it. I live in the northern suburbs - pooraka to be exact. thank you in advance as its very much appreciated. ideally i just want a third person's opinion and help.
Yeah I know what you mean re one problem after another... that's cars for you :(
I'm in Golden Grove (and Oakden) so it'll be easy enough to get to you, or you to me. Any time from about 7:30pm on during the week is fine with me.
I'll PM you :D
i still havent been able to get all cylinders firing but thanks for your matt especially in the condition and time that it was looked at. Although i was recommended to check the ignition starter (igniters) since these tend to fail and cause the coils not to spark. Hope this fixes it.
Sh$% man stop making me hyperventilate sorry to hear you've had drama's with it I never had half the problems you've had apart from blowing up gearboxes hopefully this is the end of the problems.
i hope so too mate. Its just these minor problems that keep creeping up now and then that is annoying. oh btw, ive heard that you are the new owner of a nice imported 4 dr line - congrats mate.
sil80 aint that fast anymore. the white r33 you saw when you were here blows its doors off now. hope you enjoy your line and active in these forums particulary the sa section.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
