  • Replies 44
Hmm this has got me interested.  White cam covers in white R34.  What do yas all reckon?
Saw a GTR in a magazine once with a white engine (I think they painted the block as well) and everything else was black. Looked like the engine was just floating in the engine bay, looks very cool.
dont paint them, polish them .. polished alloy is da bomb. All spray paint is shit, the only paint worth getting them done in is 2pak, and its not that cheap, i just think spray can paint is crap .. Thats why i polished everything i could get my hands on ..
But this is just my opinion, alot of people would probably disagree with me ..
Actually 2 pak isn't that expensive, when you consider the small amount needed to do cam covers. The expensive part is the time that the painter spends on the job. If you did all the prep work youself (sanding, etch prime, light sanding of primer), the job can be done for a lot cheaper. We did one of those 3800 V6 holden engine covers & a strut brace in 2K green pearl the other day and the boss only charged him $10!
on this topic mick do u happen to know the best way to polish rims with the grey coating to get them to the polished alloy stage? got a set of sparcos im wanting to do n im not gonna pay 250 per rim to do it
Kamikaze33 i heard that Wheels in ballarat polish rims for $50 each .. I carnt be too sure though, u shouls try give them a call. Now about polishing them yourself, its easier to get the tyres removes from the rims, then use paint stripper to remove the paint or a wire brush attachment for a drill to get the paint off. The rime will be pretty easy to polish is they will be smooth to start off with, its not like a plenum. You could use fine grade wet and dry paper to do most of it and then use a polishing mop attachment to a drill that you can buy at most bunnings stores for $30, the kit comes with 2 different mops, one is for heavier jobs and the opther is a while soft mop for finishing detail, you get 2 little blocks of polishing compound as well .. Wheels arnt hard they just take time .. If you havent done them buy the time you move down here i'll help you .. Depending on what rims they are and how many tight spots to get to there are they should be easy .. and the bench grinder with the mop attachment will be able to do alot of the face of them ..
i thought u were talking about the cam covers .. they are alloy, but yer the cab belt cover im pretty sure is metal .. if its metal the best thing to do then is either paint it or get it chrome dipped .. i dont know how you would go polishing it up and then laquering it .. the laquer would have nothing to realy bite onto it was polished like a mirror ..
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
