Hey guys
went to willowbank test and tune last nite
after doin a 16.1 last time completely stock AUTO
i have improved abit with the help of a FMIC
avcr controller set on 10psi
CES racing split dump .
My time i did last nite was 15.2 with a .640 reaction time .
im off saving for my next lot of things to do to make it quicker
series 1 1993
had 122.3rwkw stock
and after those little mods it did 166.9rwkw
so slowly moving up .
Would this time that i did be accurate to the dyno rating 166.9?
considerin the reaction time and all of that?
my 60 ft time was 2.356
and did 91mph.
so yeah dont know whats goin on there then.
i'll get the car looked at and do what needs to be done
next thing is injectors, fuel rail, fuel pump, cams,
trans cooler, stg 2 quick shift, highflowcat, afm then turbo.
so should be gettin a bit betta from then
well done but im sure you would like to do better. Do you only have a dump pipe with the rest of the exhaust stock?? If this is the case then that will be a big restriction.
Also did you launch the car just by planting down the foot in 'D' or did you stall it up as far as it can go then taking off right when boost comes on??
Good stuff Mate , keep pushing it :)
My auto ( when it was stock turbo & ecu ) made a best of 13.4 @ 106mph (280 rwhp)
I didn't lunch an auto until mid 300s rwhp , & even then it was only heat that killed it!
I'm trying "Redline racing ATF" now ( with a bigger cooler!) , I'll keep you informed.....
GO THE AUTO!
when i went down the quarter
i stalled it up to about 2500 and .4 or .5 boost in 1st gear
then changed to 2nd and drive
Should i try goin down in just drive ?
I have CES racing split dump 3inch
Catback 3 1/4 hyper Medallion exahust
AVCR controller set on 10psi
600X300X75 hybrid intercooler
K&n panel filter
APC did a compression test and found the 6 cylinder was 130 and the rest were 150
I havent been in another auto yet, but it feels like my gearchanges between
2 and 3rd are pretty slow or is it just normal.
pulled a alright skid though hahaha.
What other things should i be lookin at to get myself in the 13's bracket?
  • 3 weeks later...
I aslo have an auto and am about to install a Greddy Profec B-spec II. I want to set the high setting ti 11psi. Will it be OK to have it on high for the entire race. Should I launch on low then go to high. Mines all whell drive so I dont need to worry about traction. Ill have a bigger transmission cooler in by the next meet.
My time i did last nite was 15.2 with a .640 reaction time.
Your R/Times don't count. The timer starts when you leave the staging line and cross the finishing line (otherwise most rotary cars would be doing 2min 1/4's :))
my 60 ft time was 2.356 and did 91mph.
. With some more experience you will easily drop this to around a 2.1sec 60ft which should put you in the mid to high 14's with no mods at all.
bazr33:
Well done on the time. As everyone will continue to tell u....practice on your 60ft times.
Did you have your Power button on & O/D 'off'? Coz I believe that helps with the launches & gear changes.
Gear changes normally are pretty slow in the auto (approx 1 sec....zzzz). If you’re interested, currently theres a group buy for an upgraded valve body (shift kits) from M/V Automatics - highly recommended & will give the manuals a run for their money.
As HR31 mentioned, do the car a favour & get yourself a high flow cat immediately!!! & if after that, given your mods, your tuner cant tune you over 170rwkw, I'd seriously look for a new one.
For a helpful comparison guide search on the drift & drag forums (the ones by 'benm' are insightful). All the best mate :)
burkey22:
I believe with a fairly dead stock Stagea you can safetly tune upwards of 10-11psi - (dont know your mods though). If traction on your launches isnt an issue just stick it on hi.
For a helpful comparison guide search on the drift & drag forums (the ones by 'benm' are insightful). All the best mate :P
12mths, 30 runs, ~$3,700+ spent and only a 0.5sec improvement.... Yup you'll learn lots from me :)
  • 6 months later...
i did 15.1 at wsid. auto r32 gtst 3" exhaust,pod filter and 11psi.
O/D was OFF and power was on,even had my mirrors folded in.
can anyone help with launches in fairly stock auto's? at what rpm should i change to 2nd? it feels like it should change earlier,but it likes to redline.
Does manualy shifting the gears make it change quicker? or is it an illusion?
Edited by RSTME
Go the auto
stalling up in N and smaking it in to drive and i through you would leave your gear box at the start
Greddy e manage with ignision harnes + wider tyers
out of interest i have a 250 rwhp auto
how would that go i wonder
james
Sad to say it but thats still slower than a stock off the showroom floor 265 powered auto 1973 valiant sedan.
Good to see you getting some improvement though..keep it up
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
