We have been getting lots of inlet and exhaust manifolds extrusion honed, match ported and doing before and after flow bench tests. The ones of interest for you guys are obviously the RB20-5 and RB26. All testing is performed on a $36,000 flow bench. It is digital and logs results and very accurate. It assimilates what happens in engine although is not an exact as hard to recreate 25 psi or more, although it is a very good indicator and probably the best available in Australia. All tests are performed at 25 inches of water.
The RB26 exhaust manifolds require a bit of match porting and as expected the middle runner is the worst and stock flowed 138.2cfm, after extrusion hone 159.9, then with match porting 167.4cfm. We also got more flow from the outside runners and after honing they are all in better balance as we port and extrude hone the middle ones more. This is quite a gain and less turbulence and restriction by smoothing out coarse casting on inside of manifold and removing the edge of the flanges to stop gases hitting and causing turbulence. Bottom line less heat more flow, more horsepower.
RB20-25 info not handy as we did this a while ago. All I can say is the factory inlet plenum is very ordinary as there is a huge variation from the middle two runners the throttle body aims at and the outer ones. This is why we tune those runners richer with Microtech or Power FC.
https://www.sau.com.au/forums/topic/67686-extrude-hone-and-flow-bench-tesing/
Hi John;
I have been thinking about having my GTR exh manifolds extrude honed and I understand from their Vic agent that impeller ie exhaust side turbo housings benefit also. Appreciate the flow bench results but do you have dyno charts for comparison particularly on a stock motor? Happy to offer my stock car as a test mule if we can come to an agreement on cost. I also have R34 N1s to add to the equation at the same time.
Regards
Scooby
Obviously to do a proper test it would be changing to extrude honed manifolds only. We know they work from flow bench test and common sense using eyes and feeling it before and after. When you factor in how hard and fast air gets shoved through it then makes sense. My zed is testimony to this technology as it makes huge power especially down low and this is probably part of the reason. 200rwkw at 34000rpm over 400rwkw top end with stock manifolds match ported and extrude honed.
All about thermal management and flow. Engine is like a big pump and if easier to get in and out then less heat and stress and more power. Free power. Also note we have tested some stainless manifolds on other engines compared to factory extrude honed ones and the factory one is better and won't crack, radiate less heat and better to HPC coat as better material to bond to.
We just did a big batch and getting some Hightemp black HPC coated and will have them available soon. $540 a pair exchange and probably extra $150 or so high temp black coated.
Details and prices on our site very soon.
Cheers mate. Mine are custom modified to suit the RB25 so I'll have to get them done myself. Gotta pull the head to find why 1,2,3 are low on compression and 4 has no fuel from injector so might as well optimise the setup. Just running GTR34 BB turbs but dreaming of 2530's...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
