hey jus in need of some help dont know what to do....
basically i took of my brake callipers to spray them red (yes i know rice haha, they look pretty good but) and yeah took the wheel off (was doing front left wheel) and unscrewed evrything the calliper was attatched too. and wen the callipers split into its 2 peices, all the brake fluid just started leaking out.. so i dun kno much about brakes we jus assumed u can jus put it back in so we jus tinned it LOL.. and yeah so we jus let the brake fluid run and wen it was done sprayed the calliper and yeah put everyfing back on. so yeah i turned on the car and realised i had no brakes after pumping the pedal for ages... and rememberd i had no brake fluid so i was gna put the fluid we tinned bak in, but my mate threw it away already... so i went petrol station and the only brake fluid they had was DOT 4.. on the cap it says to use DOT 3, does that really make a difference?... so i jus opened the cap and refilled it to just about over half way.... and yeah probaly drove for abit 5-10min or so.. and the brakes started to come back and now the brakes respond quicker... then i talked to my mates dad and he was telling me soemthing about bleeding the brake lines... so are my brakes gone cuz i dont think i done that bleeding stuff... if anyone has a guide on how to do it properly cud they please steer me to the right direction? cuz im abit packing it one day my brakes wont work. thanks!!
https://www.sau.com.au/forums/topic/67738-brake-fluid/
Dot 5.1 brake fluid is what you should be using, as its better than the dot 4 and obiviously dot 3.
If you undid the fluid line and let air into the system then you need to get them bleed as there will be air in ur lines and ur brake wont be working 100%.
Oh and the main thing, FFS use paragraphs in ur posts as its a real bitch to read what you wrote.
https://www.sau.com.au/forums/topic/67738-brake-fluid/#findComment-1257455
lol...yeh paragraphs would be nice.
After reading that I'm hoping you didn't spray the spot where the two parts of the caliper
joined (middle). You didn't need to take every part of the caliper apart, just use masking
tape.
You also definitely need to bleed them now as inasnt said. Do you know how to do that?
https://www.sau.com.au/forums/topic/67738-brake-fluid/#findComment-1258659
Dont stuff around with brakes if you dont know what you are doing .
Take it to a brake specialist and tell them to check the brakes .
If you have air in the brakes it doesn't matter what fluid you got in there they are not going to work . The will only work after you pump them several times , the first time you press the pedal it will go to the floor .
You have to bleed the whole system and there is no point doing it yourself .
https://www.sau.com.au/forums/topic/67738-brake-fluid/#findComment-1262943
my god thats crazy... why didnt you just spray the calipers on there if you didnt know what you were doing?? you just put a plastic bag around the disc and around the suspension and away you go.
bleeding brakes is not hard by the way, but if you've pulled 4 pistons calipers apart you should replace the o-rings inside.
there would be heaps of threads on bleeding brakes so try a search.
cheers
Linton
https://www.sau.com.au/forums/topic/67738-brake-fluid/#findComment-1270568
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
