My no. 2 injector is weeping a tiny bit of fuel through the o-ring. I went and got some replacement o-rings from an EFI place only to find they are too big (after pulling the fuel rail off of course).
I have o-rings that will fit - but they came out of one of those big packs from Supercheap - my question is - will these do - they look like good quality? Or do I need ones that are made out of a special fuel+heat resistant rubber ?
Paul
https://www.sau.com.au/forums/topic/67845-injector-o-rings/
Ignore above - the answer is yes they are specific fuel type o-rings.
I have been told that these o-rings for gtr injectors need to be genuine nissan ones for r-32 gtr's
Just to confirm you got these o-rings from supercheap auto and they fit your r32 gtr injectors? So what I was told could be misleading?
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1258357
Yeah sounds right - will give nissan a call tomorrow morning.
I was just wondering if the normal off the shelf rubber o-rings you get at Supercheap/Autobarn/Repco would do for injectors - however it seems not.
Now I wonder what Nissan want for 6 of these little things .... better make sure I am sitting down when I call them ....
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1258426
Part numbers if anyone needs em in future:
R32 GTR / RB26DETT
Rear O-ring - 16412F - $9.50
Rear Insulator - 16603F - $13.35
Front seal - 16603G - $5.35
Faxed me the diagram - got all the part nos for fuel rail etc - wish I had that damn software they use.
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1259534
Turns out it is the injector body that is actually weeping fuel.
The first thing the guy at EFI hardware said was "are you sure it's not the injector itself, those injectors are prone to leaking through the body" - guy at nissan was also doubtful that the o-ring would fail.
Damn shame because now I gotta waste money on a replacement stock injector when I should be purchasing a bigger set for use with the PFC when it arrives.
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1262653
A few of mine weeped. I replaced all seals, still leaked. Ended up putting the new seals on a set of late model R33 GTR set of injectors I bought. Annoying, but you can't fck around with fuel leaking in the engine bay..
Were these a straight replacement with the stock ECU ? No difference between R32 and R33 variants ?
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1284550
yes 32-34 injectors are identical.
I also tried and failed with some cheapie aftermarket o rings....stick to the real thing from Nissan.
BTW while we are on it, get them cleaned and flow tested. I run 4 sets of injectors thru that process before I actually found a set that flowed over 400cc/min (they are rated at 440cc/min new). Some of them were *dangerously* low....cheaper to test your injectors than to rebuild the motor :P
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1286664
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
