My no. 2 injector is weeping a tiny bit of fuel through the o-ring. I went and got some replacement o-rings from an EFI place only to find they are too big (after pulling the fuel rail off of course).
I have o-rings that will fit - but they came out of one of those big packs from Supercheap - my question is - will these do - they look like good quality? Or do I need ones that are made out of a special fuel+heat resistant rubber ?
Paul
https://www.sau.com.au/forums/topic/67845-injector-o-rings/
Ignore above - the answer is yes they are specific fuel type o-rings.
I have been told that these o-rings for gtr injectors need to be genuine nissan ones for r-32 gtr's
Just to confirm you got these o-rings from supercheap auto and they fit your r32 gtr injectors? So what I was told could be misleading?
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1258357
Yeah sounds right - will give nissan a call tomorrow morning.
I was just wondering if the normal off the shelf rubber o-rings you get at Supercheap/Autobarn/Repco would do for injectors - however it seems not.
Now I wonder what Nissan want for 6 of these little things .... better make sure I am sitting down when I call them ....
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1258426
Part numbers if anyone needs em in future:
R32 GTR / RB26DETT
Rear O-ring - 16412F - $9.50
Rear Insulator - 16603F - $13.35
Front seal - 16603G - $5.35
Faxed me the diagram - got all the part nos for fuel rail etc - wish I had that damn software they use.
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1259534
Turns out it is the injector body that is actually weeping fuel.
The first thing the guy at EFI hardware said was "are you sure it's not the injector itself, those injectors are prone to leaking through the body" - guy at nissan was also doubtful that the o-ring would fail.
Damn shame because now I gotta waste money on a replacement stock injector when I should be purchasing a bigger set for use with the PFC when it arrives.
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1262653
A few of mine weeped. I replaced all seals, still leaked. Ended up putting the new seals on a set of late model R33 GTR set of injectors I bought. Annoying, but you can't fck around with fuel leaking in the engine bay..
Were these a straight replacement with the stock ECU ? No difference between R32 and R33 variants ?
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1284550
yes 32-34 injectors are identical.
I also tried and failed with some cheapie aftermarket o rings....stick to the real thing from Nissan.
BTW while we are on it, get them cleaned and flow tested. I run 4 sets of injectors thru that process before I actually found a set that flowed over 400cc/min (they are rated at 440cc/min new). Some of them were *dangerously* low....cheaper to test your injectors than to rebuild the motor :P
https://www.sau.com.au/forums/topic/67845-injector-o-rings/#findComment-1286664
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
