Well, I got my second tune at a good tuner here in mackay, North QLD (fark its hot)
anyway - Mods (only power listed)
Fully Sheilded Pod Filter
Stainless 3 inch Turbo to AFM to Pod filter Pipe
DNA motorsport Bleedvalve, set at 12psi
Exhaust Cam gear set to 0 Degrees (anything else and it lost power)
Apexi Power FC with HC, and Tuned with HC
Full Exhaust
Hi Flo Cat
Split dump and front all in one pipe (custom made by mate, extended wastegate pipe)
600 x 300 x 75 Hybrid Intercooler
Stocko Intake plenum
No heat sheilding at all
Stock Fuel Pump
Stock Injectors (PFC reads 80% duty cycle on full load)
Dyno Results
Does anyone know how to increase off the mark Torque? And whats with that big dip in the middle of the torque?
I'm looking at a Garrett 30-40 Turbo, with a .63 AR exhaust housing, because I freaken HATE lag. (heheh maybe I should just buy a V8) Will this help me to 250rwkw with a fuel pump and injector upgrade?
Will the unopened motor handle it?
nice dip there right where u want the most torque! :P dunno, too lean/rich? hehe, doubt it if u got it tuned...heat maybe?
throw a bag of ice on the engine BEFORE u start it :) make her run cooler hehe...nice power but ;) what boost?
Hi, there are a few things that concern me, that would be answered by a bit more data. Do you have an A/F ratio graph? And a Boost graph? Where is the base ignition timing set at? Checked with a timimg light? This is particularly relevant in light of the zero effect from tuning the exhaust camshaft timing, this is usually a sign of retarded ignition. And that lines up with the lumpy torque curve.
When tuning the exhaust camshaft timing I personally look to hold the max power pretty much as it was, but increase the average power from 4,000 rpm to 7,000 rpm. Usual results are 10 to 15 rwkw increase in average power and around 3 to 5 rwkw in max power. That's what seems to make the car the fastest.
:D
PS; I hope you are not planning on running the standard turbo at 12 psi for long periods of time in Mackay.
Sydney Kid, I will try and the the information that you are after this week afternoon. I wouldn't mind seeing what you think.
I forgot to add, I run Toluene, 3l to 30l of fuel. Without it, the car detonates like a bitch.
Oh, and I drive it like a pig, flat everywhere (that is safe to go flat), always on boost, hot or cold day, so yeah. You're scaring me... Could I blow it up? Tuner says its running really good.
Oh, and the powerFC shows the AFM is maxing at about 6000rpm upwards. But one of the tuners (not the last one) said that the map is set properly so that the AFM has no effect anyway.
I'll al;so try and get some pics. I took this one with my phone yesterday, skyline.jpgbut I'll try and get some of the motor, and the custom mods. (mate is a boily that does Tig and Mig welding like a champ)
I'll also get a pic of his plenum. Its his own creation, and he's put dual throttle bodies on it..
$100
NA RB30 bottom end..
hahaha
sorry, that's my answer for everything now..
hehehe thought of that, don't you worry...
dude, if your adding stuff to stop it pinging.
there is something dreadfully wrong with the car.
take it and get it tuned properly would be my best suggestion.
Adding stuff is a sure sign something is very much not right.
You'll be surprised how a properly tuned car will go especially with your graph as it looks quite sick and your running a PFC.
Get some more info indeed.
strange i have a very similar config with 172rwkw series 2 rb25, powerfc same mods etc and im hitting afm max and injector duty at 98.9 % which is much much higher than your 80% very odd
Hey how's it going. I take it Damo tuned it again this time or did the other lad do it. He had my Skyline running with my setup and there wasn't a hint of detonation, that was with 10 degree's base ignition and 15 advanced at 19psi, and that was on Moranbah qaulity Premuim. so I don't know what's up with your pinging. does he know your running the additive? if he's tuned it with the additive and then you fill up and run standard it'll explain it.
Your not wrong about the flat out bit, saw you last week and went to give you a wave and you where past before I could get the hand of the wheel. Good to see your getting some good gains out of the machine. Going to live down brissy way this weekend so cop-ulater.
if your looking for 250rwkw go for hks gtrs instead of gt3040
the 3040 will be a bit more laggier. the gtrs has been proven many times to handle 260-270rwkw at its peak and its much laggier than stocker turbo, well so the drivers and graphs seem to represent anyway, much less than the 3040 one would assume
Hey Wurthy! Good to see you.
Yeah the latest tune was done by Damien, and I let him know that there was a 10% mix of Toluene in, and he said I'll have to run it all the time.
I don't mind, because I can get it for $48 for 20l, and it does a hell of alot better than "octane booster" and works out cheaper.
Paulr33, I don't really want much lag at all, so do you think a Turbo with a .63ar exhaust housing would be good? Something around the 500hp mark? Would I run out of top end serverely with a housing that small?
Someone told me that a .63AR exhaust should be at full boost at around 3000rpm. Can someone verify this?
theres a thread about 6 months old called rb25 dyno graphs or rb25 turbo graphs and it shows various combos of rb25 with various turbo configurations. hiflow and gt-rs showed the least amout of lag and good topend. the gtrs was ballpark around 260rwkw. you should be able to find all the info you need to make an informed decision regarding lag and what size to get
awesome, I will go for a hunt, and have a look at it.
Also i the meantime, I'll grab those figures for Sydney Kid
I can't find it... Are you or anyone able to help me? Would be greatly appreciated.
umm.. all this talk about tolulene... and the fact that you are going to use it constantly..
has anyone informed you of the side effects?  to your car that is...
yeah there are alot of myths.... Like it east fuel hoses etc, but I haven't had any problems whatsoever with it, and I have been running it for over 6 months, in 10% Mixes.
And I mentioned that I would post a pic of my shielded POD filter.
user posted image
Notice the nice stainless steel pipe, right to the turbo? Talk about woosh when coming on boost...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
