Mud,......thanks for the link, nice tunes, nice bit of skirt, but don't know if i like the way the door near opens 100% then goes vertical, i wonder if that design is pacific to VDC or all kits, it sort of defeats the purpose i think as you can get out without them haveing to go up...............MEL! Check out www.ultimatez.com for some power upgrades, they have a brilliant package deal there-cold air pod-headers-exhaust-pulleys n belts-clutch-flywheel...$3643.90us check the extra component kw....Mmmm will have to consider it i think.
you don't need to open them 100% before raising, I'm pretty sure it explains it in there somewhere. You just need to open the latch so the window clears the roofline, then up she goes.
  • Replies 41
r33 impul freak........i took my liner in there for a service and they didn't put my sump plug back in properly, if it wasn't for Ace exhaust whom i took the car to straight after for some work i would have had a siezed motor.......before that i asked Garth for a c.f.bonnet and he never got around to ordering it, i even, some months later asked for a c.f.bonnet for the z and he never got back to me.
350zed.......... off the floor it came with stainless exhaust, k&n filter,brushed door sills,luxury mats including boot,cargo net............i have on the way some TopSecret special edition 18" by 8.5 front & 9.5 rear....245/35 & 275/35 tyres.....orange LED door sills & barker bar (rear strut bar) orange LED z badges (side of car) white side markers with white LED's (nose cone) ......a 4 position short shifter.....5 wire grounding kit...........i plan on getting a Chockets 3d c.f wing from www.gpsports.co.jp......c.f.bonnet (pic on profile)...... c.f radiator cooling plate .......... powerchip from www.powerchip.com........full power package from www.ultimatez.com........and maybe a kit i have my eye on to top it off. Other stuff in consideration...3 pod a piller gauges....c.f. roof scoop/engine cover/battery cover/master cylinder cover/dash.etc.....maybe a full titanium exhaust with titanium headers when i rob another bank....upgrade the to 6000k hid high beam and the list goes on......maybe in 2 years i will have it all......BLOODY CARS! :)
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
