  • Replies 91
if anyone wants xenons in the r34, contact Nathan at Grey Imports, 9519 5150, he converts most of the r34 headlights from xenon for compliance, and I'm sure he can help you out.
so have ur 'TCS Off' and 'SLIP' lights sorted themselves out? - i just took my car for a spin (after about 1 week) and got engine light and the 2 TCS lights, ran like shit for a while, pretty lumpy and rough, but bout 10 mins more driving and it was smooth as again. I was doing the whole turning off and on thing as well. Didn't work but then after a few mins driving, tried it again and the engine light went off.... bit more driving, off/on - and then the TCS lights are off.
According to the manual, when the 'TCS OFF' and 'SLIP' lights are BOTH on, it means the Traction Control is 'temporarily unavailable'.
My car is a manual by the way... so you've had no more TCS light problems?
yeah mines all sorted out...it was a wrong fuse in place....stereo installer stuffed up...causing the ecu to register all kinds of errors when hooked up to the nissan consult machine. With ur problem, definately bring it in to a nissan dealer, let them hook it up to the consult machine and go from there.....
been in Malaysia for a week and a bit, just took the car out then and i couldn't get any of the TCS or Engine lights to disappear, sounds like it's missing a bit.
With the 'bring it to nissan dealer' there is slight problem as it's not rego'd so i can't actually drive it anywhere. I guess i could get a temp rego, but then the drive to the dealer, the car wouldn't be insured... a little risky. A mate of mine told me to disconnect the battery terminals overnight... so i'm going to try that (gotta search for how to do that) - but yeah, if not... will have to get Nissan to take a look.
how do u get into diagnostic mode for 34's?
cheers,
daniel.
cheers,
daniel.
You need to short the circuit for 2 of the pins in the diagnostic port.
Do a search you'll find all you need to know about it.
Sounds like your coil packs are on their way out.
Run the diagnostic and see if it says ignition circuit failure.
i don't know if the problems simular but TCS, Slip and Check engine would come on randomly when driving long distances (about 15km), i checked out the engine with the car running and found a huge leak in a vacume line running to the vacume sensor (the little thing tucked away next the brake cylinder). After a quick repair job, the boost gauge now shows vacume but most importantly the TCS problem seems to have gone! I can only suggest checking every vacume line in the engine bay, since a vacume leak or low revs can trigger the 'check engine' light.
i really don't know much about engines, so a vacuum leak i'm guessing it's not going to be leaking a fluid anywhere... what exactly are the steps involved in checking the vacuum lines? where do i look? cheers...
Well i disconnected the -ve terminal over night (should i have disconnected both terminals?) and took the car out bout 1 hour ago, so prob got about 20 hours of having the -ve not connected. Ran smooth for a bit, no lights, then after about 5 mins, TCS and Engines lights both came back on and then the car started to ran a bit rough, lumpier idle, not sure if it's missing a bit...
coil packs? my car is a manual, does it still have coil packs?
not from Malaysia, just have family there. born here, half australia, half chinese.
hehehe, well i did some searches, and from some threads here it just said 'negative'...
fine, i'll do both :)... try this again... :rofl: - dude, i'm a total newb with this car thing, i wasn't sure how to disconnect the terminals! just happened i had a spanner to fit the nut on the terminals...
what do you think about this whole pumping brake thing?
and if disconnected both terminals doesn't fix it? Take it to a dealer?
i left the engine running and happen to hear a whistle which turned out to be the vacume leak, i was lucky to hear it but some leaks you can't here and would need to visually inspect the hoses and their connections. However the bad news is that it didn't exactly fix the problem, it still does it but not as regulary as it did.
well took the car out a little while ago for about 15-20 mins, after having BOTH terminals disconnected over night, and she ran fine. No lights at all, no scooby moments, ran smooth.
I don't know if it because of both terminals being disconnected, or just happened to run ok... but it's fine for the moment.
that looks awesome. I've got this little ass laptop from when i was a at school, Toshiba Portege, small as anything (cos everything is external) but would fit in the glovebox, so the Nissan Consult thing looks awesome...
Troy, as far as i know, car has never been jumped... oh wait, the compliancer did say they had to change the battery cos the original one was flat, so if they did that, that means someone would have had to discover the fact it was flat and maybe jump it at some stage. Why do you ask if it's been jumped?
and do Manuals have coil packs? all the coil pack stuff i've been reading at in regards to 34's seems to be with auto's???
i'll take the car out again tonight and see if it does it again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
