I have an R34 GTT with the standard 330cc injectors. I have some 480cc Nismo ones to put in. I am running the stock ECU which has been chipped.
If I put the bigger injectors in, will my car run?
Will it start?
Will it run but foul the plugs?
Will I be able to drive it halfway across Sydney to get it tuned?
Thank you.
When I swapped my R32 GTSt injectors for GTR 440cc injectors mine started on the stock ecu, but ran meag rich as expected ( like a semi pulling away from the lights! :D )
Dunno if I'd be driving it with it like that to get it tuned though - maybe a good case for a tow truck
I take it the ecu hasn't been chipped to suit the new injectors? If it has, then I'd give it a go
The ecu hasn't been chipped for these injectors.
I've never done anything like injectors before so I don't want to be pulling my car apart for 3 days in the carpark of the place that is doing the tuning. As you can probably tell, I'm also trying to save some dosh by doing it myself.
Anyone got any pointers for me?
So I take the top half of the plenum off... then what?
disconnect fuel supply first?
take fuel rail off?
do injectors just plop in or are they bolted in?
do I need to get new rubber o rings on the new injectors?
should they be lubed with something before putting them in?
reuse the same plenum gasket? is that the only gasket here?
take fuel rail off?
disconnect fuel supply first? Not necessary if you are quick
take fuel rail off? yes only a couple of bolts
do injectors just plop in or are they bolted in? Remove clip, Plop out
do I need to get new rubber o rings on the new injectors? No new o-rings
should they be lubed with something before putting them in? No lube
reuse the same plenum gasket? is that the only gasket here? re-use, try not to damage as they are f#$king expensive
  • 3 weeks later...
For anyone reading this... Take the top half of the plenum off. Sounds so easy doesn't it? WELL IT'S NOT!
Haha. As well as the bolts that go around the outside of the plenum, there are 3 underneath. You need a thin socket (can't remember if they are 10 or 12mm) the kind that fits on a 1/4 or 3/8 inch drive. Your ordinary socket with half inch drive will not fit in there.
Don't even think about trying to pull the rail off without removing the top of the plenum, it might look like you just need to unbolt one more thing or remove one more hose to give you room but it will never happen for you.
You have been warned.
Notice Fatz say 1-2 hours. Abo Bob say allow 6 at least.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
