  • Replies 172
Just fitted the intercooler piping from Raf yesterday. Took me two days cos i didn't have the correct tools and had to source for them. Overall, the piping quality is good but u have to cut away a fair bit of the fan in order for the top pipe to go across the engine without touching the blades. Kind of worried now cos i have consulted a few mechanics and they have all discouraged cutting of fan blades.
Also, the clamps given are useless. No way u could fit them in.....Spend lots of time trying to get them fitted but ended up using the old clamps for my original piping.
Also, i couldn't bolt the piece of metal sticking out to the engine to hold the front pipe in place because i would have to cut even more of the fan blades. so i ended up using cable ties in the meantime before maybe getting someone to make a bracket for me.
By the way i fitted them on a S1 R33 with some help from a guy on the forum.
Babylon....Gimme your email and i will send u the instructions.....Just got the kit fitted on my car yesterday. Seriously the instructions are not much of a help.
Damm i wanted to buy one and do it myself
Is it hard? coz i have no phuken clue what i am doing?
I rang around and the cheapest i found for a pro installing one was $450
[email protected]
Thanks man,
i wouldnt say its hard, id just say it takes some people more time than others. ill post as much info as i can when i get mine.
any word on the arival or is it still sumtime b4 the 6th??
Babylon....Where are u located??? If u are from brisbane try option1garage. Got a quote for $250 to install the kit and trim the front bar to fit before i decided to do it myself. But end up with Jay helping me out most of the time.
ahh shat im from syd dude but thanks anyway :)
That sounds like a nightmare!!!
I have personally installed 3 of these kits on R33's and apart from the clamps all were perfect fits.
With the right tools I am capable of installing them in 2-3 hours depending on how lazy i am.
It is very easy to install these kits.
Cutting the fan blades is a must on even the origional Hybrid Kits which i have also installed and purchased.
Minimal effect and heat difference is noticed.
Consider that the intake temperature is 20 degree's less. :)
So when will they be posted raf?
this might be a stupid question but what did u use to cut the fan blades? can u do it while they are still on the car? anything else you have to cut?
I will ring up tomorrow to try an get a precise date. But I have given customs the documents, the money etc I'm just waiting on th warfies to move there arse.
how to cut: try a coping saw
I always used a grinder to cut the fan blades.
As the blade cuts the plastic the heat leaves the blades nice and smooth and even by melting the plastic off.
update: I talked to customs today they said the ship landed in sydney and will frieght the kits up on the weekend. Monday tuesday I should get the kits. So the very next day I will post them off :)
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
