Idle problems
My recommendation is start with maintenance. Find a ~15 year old car that is cheap for a reason and fix it up. For example, in my area F30 328i with N20/N26 are dirt cheap because everyone knows that the timing chain loves to stretch and take out the cylinder head around 80k miles. Buy one, do all the maintenance on it, if you're still motivated after that an N20/N26 can be easily modified for more power. -
It's sodium citrate, I misspoke earlier. It's a citrate buffer solution. And yes, depending on how thin the metal in the tank is this may or may not be a wise decision but if it's just mild rust it should clean off and it should be fine. -
Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing. I'm a long way from you mate, I'm a couple of hours out of Brizzy. -
New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
Just planning to have the wiring neat and hide as much as possible.
