1993 Nissan Skyline R32 GTS-T
Metallic Grey.
300rwhp
Immaculate car.
VERY regretful sale...
Modifications:
Engine:
- HKS 2530 Turbo with full braided oil and water lines (Earls)
- Blue-printed head
- OS Giken adjustable cam pulleys inlet & exhaust
- Apexi N1 exhaust system with 3inch dump/front pipe
- 3” high-flow cat. (The real thing)
- Bosch 650hp in-tank fuel pump
- Sard adjustable fuel regulator
- Full braided fuel system using Earls braids and fittings
- Huge custom front-mount intercooler and complete stainless piping kit with silicon connectors and bends.
- Blitz Dual sequential boost controller
- HKS SSQ BOV
- K&N pod filter
- Greddy oil/air catch can
- Apexi SAFCII
- Exedy 750hp single plate button clutch
- Re-chipped ECU by professional Japanese Tuner. Done here in Australia to suit our temperature/humidity and 98octane petrol.
- NGK platinum plugs (always replaced every 5000kms along with top quality oils and filters)
- Professionally coated rocker covers (Tiger gold with an orange pearl) Polished aluminium plug cover using gold anodized aluminium fasteners.
Handling/styling external:
- Lightweight 18 X 8.5 deep dish rims F&R
- Tien HA adjustable coil-over suspension with “helper” springs (gives an inch of softer suspension)
- Whiteline handling kit. Including heavy duty sway-bars and bushing kit front and rear
- Cusco strut braces
- Genuine Nissan GTR front bar, with N1 intercooler inserts, professionally modified to fit GTS-T
- Genuine Nissan GTR aluminum bonnet.
- Gold coated Brake calipers (looks like Brembo)
- DBA 4000 Slotted competition Rotors using Bendix Ultimate pads.
Interior:
- Fully trimmed in GTR suede
- Momo Race steering wheel
- Matching Momo gear knob
- New gear stick and handbrake leather bags
- Apexi SACFII custom fitted into dash
- Apexi Boost gauge fitted into existing A/C vent
- Custom fitted Boost controller hidden inside ash-tray
This car put out just over 297rwhp on a Dyno Dynamics Dyno in shoot-out-mode at 1.2bar of boost. The car has huge potential as this power is being produced on a standard ECU.
All the parts listed above were purchased NEW so you can be sure the car runs like a dream and I have been told many times before it is the best R32 anyone has seen, in such immaculate condition. It is an unbelievable streetcar with big power, handling and braking to match. It has always been stored in a garage. And received full servicing every 5000kms. Including fresh oil, new oil/fuel filters and platinum spark plugs
Price: $19,990ono
please send any questions to [email protected] for prompt reply.
This car is every bit as clean as the owner says it is.
The bonnet, front bar and grill set this car apart from the rest.
If i was looking at buying another line, this would be sold to me right now..
Free bump champ.
Free bump champ.
thanks mate!
So far I have an offer of $18,500 If i dont get a better offer in the next day i will take that.
Ben.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
