hey guys just a question
ive got a few mods done at the moment,i was just wondering who remaps standard r32 ecu's i will be gettindg an aftermarket computer round the end of the year when i have finished building a rb24
the only reason i want to remap the standard computer is that i want to be able to drive my setup as it is at the moment and need to save for other more important things like getting it engineered blusliped and registered so im just after a cheaper solution to the prob for now
but i still want to make some desent horsepower till then atleast i hope you all understand what i mean ive had this car for 12 months and im getting desperate i need to drive it so bad
mods are:
1..bigger turbo unknown size bigger than a T4 apparantly? only slightly i can post pics if ppl want
2..custom made high mount turbo manifold
3..externall gate with 12psi spring
4..front mount
5..3inch turbo back
6..GTR pump
7..adjustable fuel pressure reg
8..i think thats bout it
in about 6 to 8 months i hope to have a RB24 in,ported polished head 3 cut oversized valves and heavy springs, cams, rb26 injectors possibly bosch ignighters
and a wolf 3d ver 4 fingers crossed its a huge list but thats why i dont want a after market computer straight away i just want to drive what i have know
so if anyone knows who chips or maps or whatever you do to standard R32 ECU's
in between sydney and coffs harbouri live 1 hour north of Newcastle
any help will be aapreciated
thanks matt :D
https://www.sau.com.au/forums/topic/69403-who-remaps-standrd-r32-ecus/
sounds like with those few mods, it may take a few times for workshops to tinker and get the best settings and setup for what you are after.
You might decide the turbo isn't doing what you like it to, and put another one, or you change wastegates, or a number of factors. Each time that chip has to be reprogrammed.
What I'm saying, is that if there are a number of things that need doing overtime, the most cost effective option would be a different aftermarket ecu early on.
point taken but will my car be drivable or will it make descent power as it is what will be the limiting factor in the system and about how many KW will i make reliably consdering the mods?? obvius i cant go above boost cut so will i make ...say 220@the wheel or less?
boost cut can be removed on the factory ECU during reprogramming, that wouldn't be a problem.
good question as to what limitations there are on the stock ecu... not sure whether there are too many in Australia that have really push the boundaries. I haven't heard of too many run much more than about 230rwkw with a remapped ECU. But whether that is because they tend to get sick of reprogramming it so manually (and it gets expensive), or other inherit limitations?
I'm in the same position as you blackrb20silvia... My fresh r32 gts-t import has a fair few mods and stuff done to it but is still running the standard ECU as far as I know. I've been tossing up between getting it remapped, or going straight for the AP Engineering ApeXi Power FC (Which I'll need one day anyway, and will provide better tune-ability than the factory ecu)
They way I figure it... I can either get the factory ECU remapped ($700 or so) or buy the Power FC ($1150 without handcontroller) + maybe $600 for tuning. If you plan on upgrading the ECU anyway I reckon you're better off going straight for an aftermarket one, otherwise you're effectively throwing $700 out the window. I'm in the process of getting quotes for the Power FC install and tune, as i'm leaning towards this option.
Edit: There's an article in a Zoom magazine I have (All about tuning and upgrading your r32 gtst. stock->160rwkw->220rwkw->250+), says the factory ECU can still be used for up to 220rwKW, but you'll need something like a Z32 airflow metre to go with it? I'm not too sure here, bit beyond my level of experience :rofl:
i guess i sorta hade that kinda figure in my mind for some reason??? i was only hoping for bout 230 with this setup and bout 280 when cams injectors ect
then hoping to break into the 300 woth the RB24 does anyone think this is feasable??
Anything over 200RWKW and i think you really need to be looking at a full aftermarket setup.
I say no to that for a number of reasons first ly after market ecu is defectable.
secondly my sr20 cefiro is going strong over 1 year on aftermarket remap 220 rwkw many others the same where as every second car I hear going full after market ecu seems to blow up after 2-4 months
last reason is if you stack the chances are good they will pay with remapped ecu rather than after market
meggala
meggala
Remapped ECU's are defectable, it's just a lot easier to hide, plus once you hit the point you need a remap chances are you've got a host of mods that are technically defectable.
A shit tune on a remap will blow up a car just as easily as a shit tune on an aftermarket setup.
And if you stack it has to me PROVEN that a particular mod directly contributed to an accident for it to be held against you. Simply having more power isn't enough to hang you with, if you muck with your brakes, have incorrect wheel/suspension setups, etc. that's FAR more likely to get you in trouble.
to be honest with everyone everysingle item on your car that has been altered from the factory is classed as a defect and i mean everything so to be frank i dont give a shit what is and isnt defectable that was not the point of my Q but thanks for your concern anyway
also no one will no it chipped unless making the car excessivley rich and throwing out the a/f mix
and if you look at mods already it would normally be defected i have worked with an engineer through every decision and when the car is finished say in bout 3 weeks all will be perfect not a single defect the whole car is engineered, the car so far is spot on just looking at and slight increase in power and reliability not megga horse power
and thanks meggala i have fopund your sight usefull on many occasions and you came through again
actually chris from the TOY SHOP in cardiff told me bout DR drift so he sounds the goods. 2 respected enthusiasts cant be wrong
Hi guys,
I have some tuned chips that I am selling for $50 for a manual RB20DET. I am selling so chealy as they are simply laying around. They were tuned professionally and remove the speed, fuel and mass airflow cuts. They were tuned for th usual mods incl. 1.2bar, FMIC, 3 inch etc. If you are interested PM or call on 0401 096 663. I am happy to post for nothing.
To install it you will need to get someone to use a solder sucker to remove the stock chip. You will the solder in the cradle that I send you with the chip, instert the new chip into the cradle and drive away.
thanks mrZac what is your car dynoed at and how much torque im not after peak performance just strong performance and major reliability
524nm torque and 176rwkwss on a CA18DEt with a HKS 2510 turbo. This was a conservative tune with 1BAR of boost. Still had standard cams, throttle body, intake piping, and exhaust manifold.
Has a few more goodies now and makes more power but that should give you an idea. Power literally doubled after the turbo and ecu remap.
Here is a dynograph from an R32 GTSt with nothing more than a slightly bigger turbo and cooler=195 rwkws(Full Lock R32)
I would said the full test.. they take it into the McLeod station, shove the sensor up your batty (exhaust) and check for CO and levels. The cops down there hand them out like candy.
The only thing about remaps that I am suspicious of, is sending off the ECU for a proper tune until they actually have the car on the dyno, or have driven the car itself.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
