95 r33 skyline gtst
rego ends july
car has been rear ended pretty bad... in between the 2 rear wheels the whole back is squashed in just back to where the back seats are.. roof is not damage.. not sure if car is repairable or not. everything from the backseat to the front is in good condition.. car starts and all.. engine has around 105,000 kms. but car has NEVER been boosted so the front cut is immmaculate... car has a 3`turbo back exhuast.. i think the dump and front pipe are still fine. has airbags, cliamte control... etc...car is silver..the car is fully stock with some unknown brand bov.. it will come with a white front bar.. tahst all i can think of.. located in west syd.. will get pics tomorrow.. btw car is manual... gearbox and engine in a1 condition
looking for around 7.5k ono
ALSO sideskirts and front bar not included...also will sell with 17`rims on the car
pics here
http://www.skylinesaustralia.com/photopost...500&ppuser=7293
hey guys.. i am getting pics taking tonite.... yes the stock rims and tyres are all fine... havnt got a quote to get it fixed but had a mechanical friend looked at it and he said if the damage is repairable it would cost around 6-7g to repair.....car still has rego so if u can repair it then there is no hassle going through inspection n stuff.. good for panel beaters or wreckage
Big dollar fix if it isnt a write off:
Rear Diff Complete - $800
Rear 1/2 Complete - >$2000
Maybe good buy at $5000-$6000 to fix a R33 that has had a front end stack.
update guys... sideskirts kinda stuck so its hard to take out.. selling whole wreck minus front bar thats all...so u get the sideskirts as well
also liek i said.. selling complete.. so dnt ask me for separete parts
thanks
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
