How do you even know this R33 has had no aussie owners? Cos the dealer told you?
I know this because it was on complied on Feb 05 and is still unregistered, and its not from a dealer as such its from an importer.
Anyhow how stoopid is this , I heard back from the finance people today saying that i cant get finance on a Skyline or any other import.. Alas I can get a V8 or a WRX, but not an import.. I am pretty annoyed bout this..
Had some credit issues in the past, like 5.5 years ago. and am now 27..
I just want a skyline, maybe i have to slow down and save more moolah.. Mind u i have a very healthy deposit..
Anyone know any ways around this hurdle.
dude, just get a personal loan for the car. They don't care what car it is then. You can tell em its for a camry!!! Thats what i did (at 22 years old - last year). Interest might not quite be so good but i not sure.
Anyway i don't think thats the best price for that. Bought my 95 gtst with 73500 on the clock, aftermarket stereo, 3 inch cat back exhaust, hks pod but other than that fairly stock (from a dealer) for about 18.5k.
I'd say you should be able to get it for a little bit cheaper than that. Offer 17k or so and see how it goes, other than that keep looking. Looking around certainly pays off in my opinion (also if you buy privately you'll get probably just as good a car but for cheaper)
Anyway good luck with the search
Sure it does mean something.
So for all Skylines in Japan or just from Japan:
Thrashed by Japs
So for all Skylines in Australia from Japan:
Thrashed by Japs
Thrashed by Aussies
ba :bs!: there is no solid rule which is good or bad. A car in japan could sit outside for years, have been inside, be up north, be down south, an ex race-car.. who the hells knows. At least you can inspect the car, or get somebody who knows what they are doing to do so here.. can't do that in japan.
It seems a little high for essentially a stocker, but you're not going to find much better from a dealer. Dealer cars up here are always fairly exxy.
Why not buy one from a member sold on here?.. smoothline has a very nice white gts-t which he would sell for below that and would be much faster, and have quite a few mods and you can speak to him about a 2 year history. One aussie owner.
IMO I think its bit too much.. If u can pay 19k there are lots of nice R33/32's on the forums....
I just bought a R33 for 16k, pretty much stock, except for exhaust, rims, pod. and people say thats expensive. But its really nice and runs perfect.!
guys this post has sparked a few offers, and I am greatfull for that. Dudes, wait till I get my money soighted and Ill reply back to you all. I am not gunna watse your time looking when I am uncertain on the funds.
If any one knows how an ex bankrupt (6 years ago) can fget a 8-9 grand loan then let me know :)
or if anyone wants to get a lancer 2000 1.5lt with cash difference then also let me know
my bro imported his r33 for around 20k all up... came with (late 96 model) 64Km's on the clcok auction grade 4 and for people who dont think they can be genuine km's you can inspect his car... it is imaculate inside and out... even has sunroof
so you can get cars with low kms from japan which havent been wound back
you also have to remember jap ppl buy from the auctions to
I dont get why guys join SAU AFTER they have bought their r33 and come on and ask if its a good deal.. what happened to the informed consumer? :)
Edit: my bad, I noticed that he was indeed asking good work!
$19k for a '93 model? Its probably worth about $14k.. 19 will get you a really nice series 2.. or if you want to take the risk of importing you could probably get an automatic r34 GTT :)
Good luck with the hunt.
1. They don't know about the site initially
2. They buy their Skyline
3. They think "I want to discuss my car with others with experience"
4. Post-purchase dissonance "I think I paid too much for this car, I hope my Skyline online buddies will make me feel better by telling me it's a good buy"
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
