Ok, so I need new tyres as the ones on the rear are pretty much at indicators on the inside of both tyres.
At the moment I'm running 255/40 17 on the rear and 235/45 17 on the front.
I've gotten some really good prices off people I know, but I thought I'd check em out against prices just over the phone with shops.
I got one old bloke who asks me why the hell I would want to run 255's with a 235 on the front.
He carried on for a while about how having such a large tyre on the rear will put more pressure on the front of the car and make things like the front suspension work harder and stuff it in the long run.
Then he tells me that I won't get any decent mileage out of any tyre anyway, so I may as well just buy cheap ones instead of spending my moeny on expensive things that won't be any better.
Whilst I ignored his banter at the time and wondered why he wouldn't just give me a price on what I asked for and take my money instead of talkign me out of something and into something cheaper, he got me thinking.....
Is there any truth to what he was saying about the front having to work harder and thus ****ing other things by having larger tyres on the rear?
Or was he just full of bullshit?
wider rear tyre gives bigger contact patch = more grip at the rear... your car is RWD, so u need more grip at the rear when launching... If anything, I would have thought that a wider tyre would put more stress on components since there is a greater resistance to movement, so the shock goes through those parts that can move. eg... bigger rear tyre puts more stress through gearbox cos instead of just spinning, the tyre sticks and causes resistance against gearbox/diff...
as for the fronts... i cant see how turning with less resistence is going to stuff anything up in the long run... maybe if you had super wide tyres on the front there'd be more stress because instead of the tyres just scrubbing along (understeer) they are gripping and the suspension is left to disapate more of the energy... i dunno...
sounds like a retard to me.
there are bits of truths here and there but generally bs - just get some 245s on the back and u will be fine they will fit on sweet. The quality of the tyre you put on depends on ur driving habits etc and say what tyres you got on the front? std suspension? large wheels/tyres been put on skylines since blot, hes probably old school
you get what you pay for usually in terms of grip, a quality michelin tyre of 225 diameter would kill a 255 falken but you may wear it quicker and it not be worthwhile - depends
yeah i figured it was mostly bs
I mean, the logical way of looking at it is that a wider tyre will give you a bigger area of rubber on the road and therefore improve the way in which the car contacts the road.
I spose the crucial thing is that you get a decent tread pattern with regard to water displacement when the tyre is that large, because some may be ineffective in channelling the water away from the centre of a wider tyre.
At the moment I'm running Kumho Supra 712's, and they're pretty good at that, but in my travels shopping around I've seen patterns that just wouldn't work on a wide tyre.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
