i just got my new engine and very nice indeed what do people think how much power i would make at the rearwheels in a r33gtst put your info in and i give you the honest power figure? as it follows in mods
Rb26 stroked out to 2.8
hks crank
hks rods
hks pistons
N1 nismo cams
hks valves and springs
mild port and polished head
hks cam gears
n1 oil pump
n1 water pump
1000 cc injectors
100 mm throtlebodie
pair of 3240 hks turbos
and running it with motec m800 ecu
3 half in dump pipes into 3 inch nur spec r blitz sys
and nice new pair of fuel pumps and new fuel lines tobe put in
and nismo fuel reg
this it was ive got done and now have all built ?
as im yet to put it in the car i just want peoples thoughts of what power im going to put out in the rear wheels
https://www.sau.com.au/forums/topic/70442-my-new-rb26-28/
  • Replies 88
Wow big list of top shelf parts there, you must be aiming for the quickest land speed Skyline in the world! Did you spec the N1 cams to keep the head costs down or for better off boost performance? How about the oil pump, did getting the N1 version allow you to spend extra on the HKS goodness? What manifold are you running with the 100mm tbody?
https://www.sau.com.au/forums/topic/70442-my-new-rb26-28/#findComment-1301068
Why? Just fit it into the car and find out for yourself. Hasn't the person that built it given you a power estimate, or is it a suck (build) it and see type thing?
Most GTR's running these big babies are in the 8's and have over 1200hp...
https://www.sau.com.au/forums/topic/70442-my-new-rb26-28/#findComment-1301179
what crank is it to be 2.8????
As elluded to by doughboy, you have skimpted on some very important components that will prelong engine life, I believe if you are spending the money on 3240's you should spend an extra 2-3g on a good oiling and cooling setup like re-proprieting the cooling system!!! Good luck mate if everything falls into place should really see aroung 600kw at the fly!!!
https://www.sau.com.au/forums/topic/70442-my-new-rb26-28/#findComment-1301393
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
