83 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hmmm,
So it looks like bronze wheels are the go. All I need to do is decide between Stace's rims or TE's..........
Thanks for all the help and comments guys.
Mike
When the gods look favourably on me and i can afford a white or Silver '94 R32 GTR...there will only be one wheel for me:)
they're nice but nothing spectacular looking.
i prefer the te37, although since everyone has them, i recommend
simmons FR19s
simmons FR19s
They ARE spectacular goddammit:)
There was a Sparco wheel years ago that was a forge magnesium race wheel that i have never seen on a car, but have seen in mags. It was an awesome wheel..must have been pricey liek those Technomagnesium wheels that you see on the Prodrive WRXs from time to time:whackit:
  • 2 months later...
hmmm.. go the r34 rims! ;) or you should get the rims thats used on the r32 gtr doluck body kit.. thats soooo horny!!!!!!!!!! :drooling:
Agreed - they are Horn!
(and I've finally figured out how to attach images in a post...) :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
