  • Replies 154
Well I want to go for a cruise, and I know Ewen and Andrew (skygtrline) seem keen for a cruise... so Im goin for a cruise :D Anyone who wishes to come along is more than welcome.
-- MEETING DETAILS --
WHEN: Saturday 21st May, 9:30AM for 10:00AM departure
WHERE: Gull service station, Monaro Highway Hume.
-- WHERE IM GOING --
Cruising down through Cooma and Jindabyne, then onto Alpine way up to Charlottes Pass via Perisher Blue. Yes it will be cold, yes if its raining it will be icy and I probably wont go. Other than that, roads should be fine, theyre good roads as well ("serviced" every year), nice and wide with open sweeping corners. Theres also BP Ultimate availible on both Cooma and Jindabyne for all your petrol supplies (albeit, usually 5 - 10c per litre more than what we pay here). Should get to Charlottes Pass by 1:00PM, dick around, frolick in the snow, then head back towards Jindabyne for some food and a drink/beer/whatever.
If you want in, just say so here and will see you on the day :P
EDIT: Theres also a $16 cost per vehicle to enter the national park. So its not "cheap" as compared to a small cruise to Orroral etc, but it is a fun drive, nice and scenic and long, and cold weather = cars like to boost more :)
EDIT AGAIN: At this point in time, I have posted this on Shogun forums as well and would prefer it not to go onto any other forums. There -WILL- be police heading down to cooma at least, and possibly even up to Jindabyne (ski season starts 2 weeks after this cruise, so they will be upping their presence) and trying to avoid any unsocial behaviour some other unamed clubs have displayed in the past. The police down that way are a very friendly bunch, and will not have any problems with us as long as were not doing any obvious forms of dangerous driving (aka "FULLY SIK DORIFTO BRO~!")
So is this still a keen happening thing???
They -should- be fine unless it,
(a) Rains and the temperature is in the minuses
(B) It snows
Long-range forecast is (or was) predicting a big dump of snow around the 19th. The ground isnt cold enough for the snow to stay (each season, you need a big dump of rain or snow to cool the ground, then a base can begin) so if it comes through it should be OK when we go up. I have no worries about the road up to Perisher, if it does snow though the road from Perisher to Charlottes Pass may be closed... guess theres only one way to find out :D
Irregardless, entering the national park past Jindabyne where you have to pay the toll, the people there will advise us of road condition and if its unsafe to enter. But as said above, the roads should be a-ok :)
SNOW OMGGGGGGGGggggggggggggggggg
(B) It snows
I'm psyched for this...even if we only get to Jindabyne and get one of the famous Kebabs i've heard so much about, eh Nik :)
shhh dont mention the kebab, people will think i have alterior motives :)
Time to reminisce about my cruise down last year...
There was scattered snow from about 5 minutes out of Canberra to about 5 minutes past Cooma, and the rest of the way to Perisher was completely white :) That was a really good dump of snow.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
