  • Replies 54
brotecs new 'power slipper' clutch is the best for sure. it's a six plate kevlar/unobtanium mix...
ATM I have OS Giken twin plate. it's not too bad but it is pretty brutal. I reckon I'll go for the sprung centre option next time too.
All these people Quoting OS gieken and the like priced at $2g ???????
Jim Berry is the man, he CAN give you the clamping preassure of your new clutch, (mine 37000) and for a 5 finger carbotic clutch for a GTR with approx 500rwhp (mine) for under $1g (with flywheel) why go anywhere else??
Im not an expert in clutches but as far as i know if you have a spring rated and tested at 37000 pound and you are forcing 5 fingers onto a flywheel rather than a WHOLE plate or even a similar spring trying to grip two full plates the 5 fingers are going to have a GREAT deal more GRIP on the flywheel and less chance slip
DONT RIDE THE CLUTCH if you are finding that you are burning clutches out on a regular basis might be worth while to change your driving techniques
Oh he is in Brissy and he DOES love a GOOD chat!!!
P.S it might bee a good idea for some of the sau members to go to someone like JIM and listen to someone with some actual experiance not just come on here and dribble total
SH!T
P.S it might bee a good idea for some of the sau members to go to someone like JIM and listen to someone with some actual experiance not just come on here and dribbel total
SH!T
A truer word was never spoken.
Adrian
The other guys to talk to if you want someone in Sydney are St Marys Brake and Clutch, we got the race car's single plate and pressure plate from there for $800. over 300kw atw no problems after a full year's racing and 2 targas.
How do Jims clutchs (wonder if its like jims mowing? :) ) handle daily driving (in traffic)?
I'm after a clutch that can hold decent power and last longer than a year in daily driving (traffic etc..) Does he provide a flywheel with it as well? or does he modify your std flywheel? I've lost my std flywheel only have the lightweight one from my twinplate (in my car atm)
Hi Duncan;
how would you rate that clutch for street use? god or dog?
Mark
  • 4 weeks later...
Blitz how did you go with the clutch? I am interested in getting one too
Kinell, due to a few issues with availability in Japan the clutch took a while to arrive but here it is.
I went for the brand new Nismo Super Coppermix twin plate kit, with lightened flywheel. The Nismo clutch was recommended to me by various people a a nice compromise between strength and drivability - I wanted a clutch that can take a hammering but wouldnt be a pain on the street so the super coppermix fitted the bill, and if it still proves to be rather heavy for street use, the Nismo larger clutch operating cylinder is also available for further improve the feel
Its being fitted as I type this, so i will provide more information on its drivability once I have taken it for a test run.
Whats the Nismo larger clutch operating cylinder all about? are you talking about a master/slave cylinder? How much are they worth, what are they ment to do?
Edit: ok quick search shows its a slave cylinder - what benifits does it provide over a normal slave?
Edit2: Ok bit more searching tells me
"When using with NISMO racing clutch kit, this product changes heavy clutch pedal feeling to lighter feeling. Bigger cylinder diameter (20.54mm) comparing with standard one (19.05mm) enables you to control clutch pedal much easier. Best matched with NISMO racing clutch series."
So how is it different using it with a nismo clutch rather than any other clutch?
Correct me if i'm wrong but it will just make the pedal lighter, its nog going to actually make the clutch less on/off?
you are not wrong. that's exactly what it does. it does so at the expense of travel. I had one in my GTR (OS twin plate). Pedal was remarkably light, but I found it didn't have quite enough travel. so that sometimes even with the pedal all the way to the floor it was hard to engage first gear. could have been a bit leaky too though, so possibly a brand new one would be ok. i just replaced it with a stock nissan slave and the pedal was much heavier, but everything worked fine.
Cool thanks for the info - Interested to see how you like your clutch Nick - give it a couple of months before making final judgement, my twin felt great when i first put it in, then after a couple of months didn't feel so good, i'm going back to a single.
Also if you end up changing the slave cyl to the nismo one, let me know what difference it makes.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
