Hey all,
Anyone else got a broken centre console latch?
You know, the little button you press to open that compartment behind the hand brake that you rest your left elbow on??
I have found on both my R33's that these were broken and didn't realise how annoying it had been till I fixed them.
Here's how I did it -
WHAT YOU WILL NEED - All you will need is a medium sized safety pin, Phillips head screwdriver and a pair of pliers.
TIME – 10 minutes.
DIFFICULTY – Piss easy! I reckon I could teach a monkey to do this.
STEP 1.
Remove console lid by undoing the 3 screws that go down into the console.
This may require a little gentle jiggling to clear the hinge springs after the screws are removed.
You should have the lid as in pic console01.
STEP 2.
Remove hinge from lid (3 screws) and all the screws (8) holding the plastic underside of the lid in place.
This will allow you to take out the latch, removing the broken bits of plastic that have been rattling round in there.
Refer pic console02.
STEP 3.
Find a medium sized safety pin, make sure that the size of the hole part on the pin is a snug fit over the latch pivot (pic console05).
Cut the head and point of the pin off, and bend with the pliers as per pics console03 & console04.
STEP 4.
Place pin within the latch as shown in the rest of the pics, then trim the pins top arm to be close to flush with the face of the plastic (pic console06).
STEP 5.
Put everything back together.
You should now have a nice firm feeling, spring loaded latch.
Hope this helps! :spank:
https://www.sau.com.au/forums/topic/70913-how-to-fix-centre-console-latch/
  • Replies 47
Fantastic.
I went to Nissan to order a new catch, and was told I had to order a whole new lid ($80). I was just about to ring back and confirm the order when I saw this post. Thanks a lot.
thommo - I owe you a beer next time your in Adelaide.
Fantastic.
hehe, i will dead set hold you to that mate :P
Fantastic.
$80? I called my local Nissan dealer and that quoted me $170 or something for a new lid assembely. So Thommo :)
ah tommo y didn't you come earlier, i pikt up a new lid from the wreckers. the way i did it was wedge a folded up piece of paper in between the latch and lid part. sometimes the lid still came up and i miss shifted a few times into third because my arm hit the lid and i couldn't pull the gear stick right back. Cheers.
  • 2 months later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
