Do Jewish people celebrate birthdays? Lets ask Joshwa
well
actually you are allowed to be within two years of the the age of the other person without going to jail
so a 17 year old can get away with sex with a 15 year old or an 18 year old with a 16 year old.... but youare totally farked now if a parent finds out you have been palying with their underage daughter again Josh :P
well
wtf, where did this law come from, anyone under 16 is underage and if you have sex with them regardless of your age or conesent your in the shit...asfaik I could look up the relevant law and section but that requires me opening up my criminal law book and its really big and im on holidays.
shhh I was trying to install a false sense of security into Josh for when the last pregnant 15 year old he was with, tries the paternity suit with him
ahhhhh ok....yea shes all legal, I swear. However, if im wrong, I will advise you for the small fee of $450/h after your arrested.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
