Hi Skliner's, how's it all....er, anyways....
1 year ago I had my sparkplugs changed (OEM Platinum $25.00 each).
I remember some massive debates on coppers versus plat, iridium etc...and their comparitive longevity/cheapness/replacement intervals, between the differing types.
I remember sticking with 'long life plugs' (decided platinum over copper), as I am not happy with the idea of having to remove the top section of a turbo 'line every time I wanna do the plugs. (apparantly often with coppers).
I have now done (about) over 20K with these plugs, car still seems ok, but it's hard to tell with these sorts of things over time, and you naturally getting use to something like a slight loss of power.
I do not want to start a debate, but i would like to know, in your opinions, if I've actually exceeded the life of my platinums (I run slightly higher than stock boost ie. 10-11 pissants). ...and if there is a chance that I'm not getting 'sparkling' performance could it be attributed to dying plugs (?). My Car idles beautifully, always has, but but just doesn't "get to the top" in each gear like I thought it did a year ago.
If my car was N/A, would these expensive plugs last longer? Have I exceeded the plug's servicibility?
If I get an answer tonight....guess what I might be doing tomorrow!!? :D
In anticipation.......
Mark Superspit. :wassup:
The coppers I ran acctually burnt the electrode off 4 of the 6 plugs. Nice hard run - 11 psi everything else stock
So now i use Iridiums, and pulled them out at 10 000kms last week and they look like new.
Cheers
Sumo
i think a rough ball park figure is 100 000km for platinum plugs, but i guess depending
on how much work done has been done to your engine and how hard you drive the car,
i am pretty sure you'd expect to see less than that.
a mate of mine used to do a full service on his gtr every 5000km, and yes he changed all
6 sparkies and all platinum.
Yes, platinums are supposed to be good for 100k kms. My experience has converted me to the Iridiums. I believe they are cheaper than the platinums (mine cost me $18 each). I run standard (1.1mm) gap, and 10 psi boost, producing 180Awkw from a RB25DET. Now the car starts easier, and doesn't miss at all.
Woah!! At 1.1 mm gap my car wouldn't start!!!
I use .75-.8.. and all seems well.
I'd like to run a bigger spark though...wish I could! (mmm.....splitfires??)
I guess I know that N/A cars could expect 100k, but a daily driver turbo nana driver?
Thanx guys.
Just found out somthing you guys might be interested to know.
i was doing some work at NGK melbourne, the other week and i was shocked to see that the life of the iridiums and platinum rated at 100,000km (as we all know) but the iridiums IX is only rated for 60,000km. just somthing to take note, as most of us push ours cars on a day to day basis.
cool, and thanq SUMO & VL .....just with extra boost my car was missing at anything above my .8 gap size (kind people suggested this as a fix when increasing boost, and it worked..thanx SAU!!). Car could start but wouldn't transition into boost without popping.
OK guys....<>60000km or <>100000kms...this is for a N/A car? With turbo cars, what could I reliably expect from even these 'high quality' plugs? 10,15K, 25K?
Surely, no plug could do 100K in a turbo car that is driven anything above granny mode and burning expensomax petrol?
Has anyone ever heard of a good quality plug in a turbo car exceeding 50k, for example??
Please, come back?...and I thank you.
NGK specify a particular plug for the turbo versions ie RB20DET, RB25DET, (which may be different to the plugs recommended for N/A versions). So if you get the recommended plug, then they should last the 60k - 100k kms.
Your local spare parts supplier should have a copy of the NGK catalogue - have a browse through that.
this makes sense...thankyou. I'll inspect this catalogue!!
But I'll stick to the original OEM model plugs then, and go for another 30k ....at least!!!!
Regards everybody...you guys are sic as.
My experience with platinums are they are overpriced but idle smooth. Also they should not be gapped otherwise you destroy a special coating. Also i have found they cause mis-fire problems on my car at standard gapping.
As soon as i changed to coppers the boost felt stronger and no misfire. I also change em every 5000k no problems.
But thats my opinion.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
