few days ago, i was driving my car toward airport, when about arrived the airport, i notice the oil pressure drop to zero when i stoped at the traffic light, few traffic passed and the situation remain the same, so i pull over my car, and check the engine oil level, and it was fine, so i start my car again(few mins later) and the car seem go back to normal as before( point to 2 on the meter) til now. So, bros, got any idea whats going on with my car on that day?
https://www.sau.com.au/forums/topic/72061-oil-pressure-drop-to-zero/
Take it to a mechanic straight away. This will kill your engine in no time.
You may be lucky and they find the fault in the guage, but if its the pump or a problem with the oil your motor wont have long to live.
All potentially valid points here.
But rather than scaring the Bejesus out of this poor guy, let's analyse what you have at the moment.
Was (is) the engine oil abnormally hot and smelly (check via dipstick or oil filler cap??).
Has the oil got any traces of 'darkness', compared to say...when you checked it last week for example.
Is the engine temp also showing hotter than normal.
Noises, do you hear noises from the engine itself? (clanking or 'tappetty' type noises).
Does the interior of the car smell odd (fumey?) other than the normal petrol smell?
I guess what we are trying to ascertain here is if there are any other 'changes' that would back up an actual and not 'indicated' fault.(??).
After all, you could simply have a bad 'sender' unit going to the oil pressure guage,
and that's it. (Indication of a fault rather than an actual fault??).
Idle your car to perform these basic tests, or do small road trips up and down your street (safely) to simulate correct operating temps.
Look for these things, drive cautiously, if you have to at all, and get back to us!!
Superspit Mark.
PS. '4D_Sleeper' could well be spot on the money here, keep that in mind too!!
I've got a dodgy sender that some times does this.
Your description of how it reads zero then after a few minutes it reads normal again is similiar to what mine does. "Occasionally"
Mine doesn't actually read 'zero' as reading zer has the red warning light come on. It reads around .5 which is a 1/4 away from the first line (2) but may look very close to zero.
I thought it may have been the rb20det motor was a little buggered as it had done a shiet load of kays.
The new motor also randomly does this.
I've had mine tested on the dyno as it appears to do it when underbonnet temps get high. Perfect oil pressure. :)
The std pressure senders are dodgy. Especially when their 12-13years old. :)
Does any one know of an aftermarket 'performance' sender?
I've heard of people who change their sender than 25,000km's later it buggers up again. It appears the replacement jobs are not of the same quality as the origionals and don't last as long. :(
Ok, how long has it since you have changed the oil and oil filter? Sometimes the oil could be just too dirty and effect the oil pressure i.e. get all boged up.
Make sure you keep your engine with good oil at all times. I change my oil every 3 months.
I agree with the comments made above, BUT until I knew it was the sender I would be VERY careful and get it to a mechanic to check it out. It wont take very long to destroy your engine IF the pressure is failing, so IMHO its not worth the risk, and I would get it checked out ASAP (I may even consider getting a tow to the workshop rather than continuing to drive it)
My intention wasn’t to scare the Bejesus out of Yap, but it is a potentially very serious situation.
Yap....do a little homework, check the 'logical and simple' things as above, and if in any doubt or if you do indeed find something that might backup you have a 'hurt engine', then call for the T-Truck.
But generally, Electronics are almost always prone to bursting before an engine does.
PS. I take it that you actually do check/service your oil regularly, I may have taken this for granted that you did!!
PPS. You're pobably out cruising as we type this 5hit out!!!
In that case.....Good Luck!!
thanks guys!~ apart from the zero oil pressure, other things seem normal, i have check the dipstick and its H, oil temp is normal too, around 85-90. and i have change the engine oil quite often, around in every 3 months within 5000km, and change the oil filter once in every 6 months, someone told me i might me the oil sensor, or sender ?? in other forum too, so.. can anyone tell me how to find out whether it is the sensor failure or other thing else??coz i dun want to buy a new sensor and end up it wasn't the sensor failure...also, how much does the sensor cost??many thanks!!!~
All seems normal?.....then chances are, if you know your car (sounds like you do), it is normal...minus your crummy gauge!! Keep 'bumping' your post 'till you find the answer on a price for your sender/gauge!!! You'll get it !!
PS. Keep monitoring the situation, just to be safe...and ...goodonya!!
holy crap, the same thing happened to me today...was heading down to the gold coast, going up a hill just before the freeway entrance, and i looked at the oil guage. was at the bottom but no red light...freaked me out
so i pulled into a side street, let it idle 30 seconds, and pressure came back to normal (3kg/cm2) and on the freeway cruising in 5th at 2900rpm was reading 5kg/cm2. temps were normal, no fumes, nothign else.
however on the gold coast a few hours later after i put some petrol in, i boosted it a lil (still under the speed limit) and oil pressure dropped again, 1 min later back to normal.
mine is prob more related to old oil, as im due for my 100K service (im actually 2K over...got the car at 101K and previous owner hasnt done major service). Im getting that done next weekend by hardcore racing in slacks creek so ill see how it ends up.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
