  • Replies 132
Christ...Ash, is that dyno figure for real? Or was it the sort of dyno that would of even given me a figure to be proud of:)
hard to say man.
leewah made similar numbers again, although the cars seemed to be on "average" a little higher.
Anyone who was in the SAU stand at MAS......when packing up...did anyone happen to find a Nikon AA battery changer plugged into the powerboards with the TV's and PS2's???
im pretty sure i threw a white battery charger in james' car when we packed up for presentations - i was told it was ron's (a guess i think) - instead it was probably yours - shoot james a PM to see if it was still in his front seat
nah no idea, when i came back the game was still going
but cd tray open, tape ripped off and no gt4. also a guy at work saw the pics from autosalon and happens to know adam. his name is jimmy k and he knows you from gym
My garage door broke this morning with Golgo trapped inside :(
Hopefully it will be fixed in the next day or so - will look for stuff (batt charger etc) in my car.
Hasn't been a good week thus far...
Greg: Don't worry - will replace the GT4 disc for you.
James, so it hasnt been a good week? Thats punishment from God for not having the handlebars! haha Get cracking...start cultivating it...massage it, put hair tonic on it, and sing to it every night before bed. I assure you with lots of love an patience it will come about nicely! HAHA
yeah thats him, jimmy m sorry not k. yeah he knows your and your sister
he saw you in the photos and goes i know that guy (to someone else who was looking at the pics). then he comes into today and goes i didnt know you knew adam k and im like um i didnt know you knew him either. haha very bizzare
Yeah - laugh it up.
I've got to be at work at 5.00am tomorrow - with Golgo and my bike in the garage, and the Niva having a busted motor... I'm not overly thrilled.
At least he's safe from theft - if I can't get in, no-one can get in :(
Basically the cable connecting the handle to the locking bars on the side has snapped - so the bars are locked in position. F*ck knows how the fixit guy will open it... just so long as he does it soon.
Time to move...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
