Hi,
I'm stuck in 3rd gear, been stuck for a while. I think the thrust bearing was on it's way out before getting stuck (it was whirring/clunking with the clutch pedal up, then when you'd press down on it you could hear it wind down for a few then stop making the noise).
Question is - if I replace the thrust bearing, along with a clutch plate and pressure plate with a machined flywheel. Will the gearbox then come out of gear? Or will I have to put a new box in as well?
The reason I ask is because if I run the car and put my foot off the clutch pedal it will try to roll forward then stall (basically, the clutch seems to pickup still).
When trying to pull it out of 3rd it will only go down a little bit but not entirely out of 3rd, if I try to put the clutch pedal up in this half way out stage grinding can be heard from the gearbox.
I've got a gearbox and clutch ready to go in, I just want to avoid putting the gearbox in for now (as I don't know it's condition) and wondering if the clutch kit itself will help.
Thanks.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/
when you pull the gearbox out to do the clutch, see if it will come loose then. Have you tried taking all the weight off the g/box to see if it will come free? Any sort of incline will put weight on the box, and want to stop it from releasing.
Cheers
Sumo
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330158
Sounds like your clutch is dragging, have you bled the hydraulics to make sure you haven't got air in the system?
As steveL has said, if you can get the car out of gear when it's switched off then it'd point to the clutch not fully disengaging rather than the box being stuck. Even with the clutch dragging you should still be able to pull it out of gear when the engine is running.
If you're really lucky you have a dragging clutch and a rooted box :( Swap them both.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330285
I can't get it out if it's off. The car is quite literally stuck in 3rd. I've tried jiggling it, heaving it, pleading to it and bashing it.
Sumo how would I get the weight off it? I've tried pulling it out on the hill it stopped, in my driveway, on the lawn, halfway down the street, on the street etc etc all different inclines. I've even 'bumped' the gearstick to shake the box on it's mounts left to right hoping it might get it unstuck.
Dave I haven't bled the hydraulics. Sounds stupid but I don't know how, I might look in the s13 workshop manual tonight and see if I can give it a go without putting more fluid in (that stuff is damn expensive). I don't think this is it however as the box had been locked out of 3rd and 4th for about a week before this happened so I think something i s wrong with the box.
Wow Dave so by the sounds of it I'm really lucky? :(
Shit yeah!
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330428
I'm afraid this is a gearbox out situation - somethings broken or bent. Since you have another gb and clutch don't waste anymore time on the one in the car just change it over.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330474
i would say you have most likely broken a selector. that is why you can't get it out of third. possible just bent a selector but i'm guessing it's cracked. in fact I'd almost put money on it.
i have a question. have you ever had any fun out of this car? it's been a pretty awful sounding 6 months so far.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330494
Yeah I had some fun mmmgtir. I picked up my (now) girlfriend in it one day, I was going for a cruise and I saw her at the bus stop and picked her up.
It broke down on the way to getting wherever we were going and it was about that time I figured out she was a decent girl when talking to her on the side of the road.... she's been my gf since :rolleyes:
Also I pulled a burnout in it once.
Other than that.. no... oh wait.. the engine fire was fun, uhm.. finding out I had no screws holding my engine in that was pretty funny.. heh no seriously I did laugh.
And uhm.. yea what else :)
I should have bought your GTiR.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330613
mate, as long as you've had some fun in it, it's should be worthwhile. it should be a good car once it's eventually sorted.
I am actually looking to buy a silvia or 180 or maybe even a 31 sky as a race car. I want to keep the GTR predominately a road car.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330630
yeah, but I personally think that an SR20 is the gun engine to have. hmmm maybe you should sell me yours....
I like that silvias are cheap, I can buy an SR turbo manual for under $9K or buy a SR non-turbo man or auto for under $5K. then I will strip it out, do all the suspension and brakes (and if needed slot in a SR turbo) and bobs your mothers brother I have a cheap race car that will probably be as quick around a track as my GTR (if not quicker) and be a lot cheaper to blow up/crash...
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1330991
Yeah the sr is a gun engine.
And yeah silvias are cheap. Stripped out there's not a lot that can beat them like that to thrap, they have lots of ready parts and yeah it's all good.
Hmm I've been considering selling my car, but I've just finished fixing it after this!!!
Hmm still got your GTiR?
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1331986
DON'T drive it!! When you get it out, have a quick look inside. Should be easy to see what's bent or broken. You have'nt lent it to any of your mates lalely, have you?.. Any of your mates [or girlfriends] sort of fairly hairy, with longish arms?? Sounds like only a bloody Gorilla could do that much damage, changing gear.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1333662
I've had a problem of my previous car not coming out of second gear before. It would literally not come out of gear, no matter what I did. It turned out to be the master/slave cylinders packing it in. Hopefully it's an easy fix for you :(
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1333948
hmmm, i'd say don't sell it. after all this it's bound to be ok. if you do though give me a shout.
GTI-R is gone mate :cheers: i miss it too. such a nice little car :cheers:
i'm still thinking selector.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1334518
yeah man i'd have to say ive nuked two SR gearbox's in the two 180's that ive owned. apparently they have a semi weak imput shaft and from what i can tell they don't like quick button off from wheel spin.
My first box i twisted the output shaft and stripped third and second. My 180 at the moment i shattered the input shaft and the main cluster. I guess the moral to this story is that maybe i should be so abusive. BUt sounds like a clutch problem to me. Had a five puck weld to the flywheel. couldn't get it out of gear then.
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1335853
i have a similar problem except it hasnt gotten fully stuck in gears yet...
Im havin trouble getting it into gears when the car is stopped.... the gearstick just wont go into forst or any other gear... and i have to use excessive force...
It's also been stuck in gear a few times... like i put the car in neutral but it still stays in that gear... ???
Any ideas ? as its gettin more and more difficult to get into gear!
Thanks
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1337948
Thanks
Mine doesn't like going into first either!
I just (whilst stuck at lights ) try to go in first rarely goes in so i proceed straight to forth (clunk sound )then go in first goes in str8 away.
Also as pushin up to first ,firmly till won't go in any more .give it a rev.
As for putting in neutral and it still in gear"start puttin $100 bucks aweek away......you will be needing it!!!
:Bang:
https://www.sau.com.au/forums/topic/72267-stuck-in-gear/#findComment-1338081
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
