  • Replies 49
hey there andrew... got the scratches fixed bud ?
I recomend u get your dump pipe 1st..this will help give you a bit more kilowatts together with the intercooler.. with this you'd be able to put the boost up high a bit..( 12psi recomended) i'd say with just that set up you'd get maybe 165-170rwkw.
with powerfc..maybe you get 190rwkw.. no need for the safc with this.
I was once told by a teacher of mine that the main way to gain power without major changes was to work on a AIR IN AIR OUT theory STD exhaust dumps on the turbo are fairly restrictive, and a 1/2 decent dump will work wonders.
Also if you havent already. y not drop in a K&N pannel filter good cheap upgrade for the intake side of things and flow very well with std "COLD" air box !!!!
Eh i think thats abit of a high figure.. power FC wont do anything more than an SAFC but will provide much more depth later on of course, if you only have the mods you stated a power FC wud be fairly useless id think... upgrade ur turbo and thats outta the SAFC league.
Jazz80,
If the dyno figure is not reading higher than the average then you have reaced the peak power/airflow that the turbo can provide in the TOP END, which is a pretty damn good effort from the tuner and possibly the freak ecu you have there.
However, Peak power isn't everything, it only dictates a certian amount of power at one rpm point. How often do you sit the car on that RPM point? .2 of a sec. ?
The PowerFC will give you more mid range and area under the curve, resulting in a car that accelerates quicker even though the peak power is the same. :rofl:
I've got
FMIC
3inch split Dump back with a hi flo cat
PowerFC
Boost set at 12psi
209.3 rwkw
420nm Torque
Stock Turbo, stock injectors, stock fuel pump, stock engine, stock cams etc.
You DO NOT need a SAFC with a powerfc, thats just stupid, and will most likely cause major problems.
I've got
FMIC
3inch Dump back with a hi flo cat
PowerFC
Boost set at 12psi
209.3 rwkw
420nm Torque
Stock Turbo, injectors,  fuel pump, engine, cams etc.
Thats a nice bit of photo shop there The Mafia :wassup:
Just kidding mate. Those figures are pretty empressive your getting there, you would have to be happy with the stock internals and turbo producing that much. Do you have a 1/4 mile time with those figures at all???
Sure do.
But its not that impressive.... My clutch is stuffed... I ran a 13.6 but things you've got to look at..
Clutch Stuffed
18" Low Profile Tyres at 12psi
JIC Coilovers lowered so the tyres are almost under the guard.
Mind you, I managed 2.1 sec Launch.. (I think) I was stoked! I'll try and find the time slip.
When I get new tyres and clutch, I'll give it another go, and most certainly let you guys know.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
