  • Replies 49
hey there andrew... got the scratches fixed bud ?
I recomend u get your dump pipe 1st..this will help give you a bit more kilowatts together with the intercooler.. with this you'd be able to put the boost up high a bit..( 12psi recomended) i'd say with just that set up you'd get maybe 165-170rwkw.
with powerfc..maybe you get 190rwkw.. no need for the safc with this.
I was once told by a teacher of mine that the main way to gain power without major changes was to work on a AIR IN AIR OUT theory STD exhaust dumps on the turbo are fairly restrictive, and a 1/2 decent dump will work wonders.
Also if you havent already. y not drop in a K&N pannel filter good cheap upgrade for the intake side of things and flow very well with std "COLD" air box !!!!
Eh i think thats abit of a high figure.. power FC wont do anything more than an SAFC but will provide much more depth later on of course, if you only have the mods you stated a power FC wud be fairly useless id think... upgrade ur turbo and thats outta the SAFC league.
Jazz80,
If the dyno figure is not reading higher than the average then you have reaced the peak power/airflow that the turbo can provide in the TOP END, which is a pretty damn good effort from the tuner and possibly the freak ecu you have there.
However, Peak power isn't everything, it only dictates a certian amount of power at one rpm point. How often do you sit the car on that RPM point? .2 of a sec. ?
The PowerFC will give you more mid range and area under the curve, resulting in a car that accelerates quicker even though the peak power is the same. :rofl:
I've got
FMIC
3inch split Dump back with a hi flo cat
PowerFC
Boost set at 12psi
209.3 rwkw
420nm Torque
Stock Turbo, stock injectors, stock fuel pump, stock engine, stock cams etc.
You DO NOT need a SAFC with a powerfc, thats just stupid, and will most likely cause major problems.
I've got
FMIC
3inch Dump back with a hi flo cat
PowerFC
Boost set at 12psi
209.3 rwkw
420nm Torque
Stock Turbo, injectors,  fuel pump, engine, cams etc.
Thats a nice bit of photo shop there The Mafia :wassup:
Just kidding mate. Those figures are pretty empressive your getting there, you would have to be happy with the stock internals and turbo producing that much. Do you have a 1/4 mile time with those figures at all???
Sure do.
But its not that impressive.... My clutch is stuffed... I ran a 13.6 but things you've got to look at..
Clutch Stuffed
18" Low Profile Tyres at 12psi
JIC Coilovers lowered so the tyres are almost under the guard.
Mind you, I managed 2.1 sec Launch.. (I think) I was stoked! I'll try and find the time slip.
When I get new tyres and clutch, I'll give it another go, and most certainly let you guys know.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
