  • Replies 310
mmmm....curbs....the secret to a shorter track :P
But that race opens the question again.....does Webber just not have it? Pizzonia qualified behind him and finished 10 places ahead......
True, Pizzonia did finish ahead of Webber - but it's not really an ideal comparison as Webber had to pit at the end of the first lap to replace the nose/front wing assembly on his car after hitting DC in turn 1.
I think you'll find that Webber's race pace was a fair bit quicker then Pizzonia's during the race. He caught DC very quickly and put a big gap on him once he got passed. He also caught Sato and pulled away once past him as well. I recall Mr Crompton actually mentioning that Webber's lap times were consistently amongst those of the top 5 when he wasn't in traffic, therefore I think it's safe to assume that he would've finished ahead of Pizza Boy if he had a trouble free run.
That being said, Webber always seems to find himself running into other guys these days...admittedly, not all his fault, but perhaps he needs to revise his driving style a little just to keep himself out of trouble.
Finally a decent result!
I think Webber drove a very good race. 4th is definately a good result considering the conditions and his starting position on the grid. I thought he was reasonably quick in the damp conditions and other than the gamble to go on slicks, he drove a very sensible race.
Importantly, he's also now back ahead of Heidfeld in the championship standings...hopefully he can grab some more points in Brazil :(
Yer nice result considering where he started from, and stopping 4 times. If he didnt gamble that first time on going out with slicks he would have finished 3rd.
True, but if Webber had not stopped for dry tyres at the time he did then he would have finished 6th or 7th. Williams made a good decision there as next lap around he set fastest first sector, then lap after fastest lap of the race, this prompted Rubens and RSCH in to get drys
Well done Webber finially a bit of luck, now all he needs is a win to finish the year.
ok, i'm a bit slow as i just watched the race last night. i must say it was a really interesting race. so good to see people changing 4 tyres in a pit stop. i'm surprised they remember how!!!
yes were it not for the first attempt on slicks webber would have probably finished ahead of button. he finally had some luck and didn't have any failures/incidents which it seems is just about 80% of what's needed for a top 5 finish these days. it was great to see him feeling his way on slicks after a few others had failed (massa etc) and setting such quick times. great move that one.
shame about montaya handing P2 to gonzo. kimi must be p1ssed off.
yeah, i recorded this one of DVD too :) i'm a bit less advanced than you though, i just have a DVD recorder hooked up to my TV, i guess it's just like a modern VCR really. I have no idea how to make clips from them and post up... what can i say i'm noob. i just like being able to set the timer and it burns me nice DVD with chapters etc so i can watch it at leisure. :)
Yup, Dvico Fusion Plus DVB-T PCI HDTV.
Each recording is around 9gb. Remove the adverts and its down to around 6.5gb, use dvdshrink and it fits perfectly on a 4.5gb dvd-r at around 70-75% compression (Sandown I split over 2x DVD-R and no doubt Bathurst 1000 will be about 5 DVD-R's :)) with awesome playback quality.
If Ch 7/10 made full length, full season DVD's available of each race, every round for every year i'd happily purchase them, until they do i'll happily do this :D
Edited by benm
Each recording is around 9gb. Remove the adverts and its down to around 6.5gb, use dvdshrink and it fits perfectly on a 4.5gb dvd-r  at around 70-75% compression (Sandown I split over 2x DVD-R and no doubt Bathurst 1000 will be about 5 DVD-R's :unsure:) with awesome playback quality.
If Ch 7/10 made full length, full season DVD's available of each race, every round for every year i'd happily purchase them, until they do i'll happily do this :(
Sweet im going to get myself into this, ive got everything but the tv card, how much? Will any tv card do?
i've got that same fusion HDTV card too! but can't be farked watching on PC. i like the sony DVD recorder i have, it's very good. simple though.
i must get this fusion sh1t cranking. benm, i may need your help mate as i don't have the 1337 sk1llz.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
